Popping Fuse
marco
.....if this is the wrong section for this thread, i apologize, just didnt see a section w electronic problems.
stuff hangs off ignition power. If you have hung
on any aftermarket stuff from the switched-hot
power, might start with disconnecting that and
see if anything makes it quit. You may want to
go to the 'Zone and look for a blade style circuit
breaker of the same amperage that you can
substitute in, at least it'll recycle back while you
are checking instead of making junk one piece at
a time.
