Sponsored by: CARiD
Replacing ABS Module
Old Sep 13, 2008 | 02:19 AM
LS2ddz28's Avatar
Default Replacing ABS Module
OK, I'm going to be replacing the ABS module shortly. It's a 2000 Z28 with traction control.
How involved is it gonna be to do this?
Old Sep 13, 2008 | 10:33 AM
Grimes's Avatar
shouldn't be that bad because it is in a relatively easy to reach spot in the front.
Old Sep 13, 2008 | 10:40 AM
jimmyblue's Avatar
Moderator
You can also delete it w/ the SJM line-lock kits or equivalent.
May be lower cost as well as weight reduction, if you aren't
that hung up on keeping antilock function.
