Sponsored by: CARiD
Cruise Control
Old Sep 27, 2008 | 10:42 PM
AFASTYZFR1's Avatar
Default Cruise Control
Cruise control stopped working after motor install......I checked switch on clutch and it is adjusted properly.....fuse is not blown.....and car only has 28k miles........any ideas?
Old Sep 27, 2008 | 11:04 PM
slayerized6's Avatar
i thought having cruise control would be great before i got my car. used it once and never used it again. dont worry about it IMO
Old Sep 28, 2008 | 07:32 AM
AFASTYZFR1's Avatar
I just drove the car from IN to VA without it....I think I'll fix it....I plan on taking the car on a few trips, but thank for the help
Old Sep 28, 2008 | 01:04 PM
dutinsss's Avatar
have you checked the line going from the TB to the cruise box and made sure it was attached on both sides correctly?
Old Sep 28, 2008 | 02:14 PM
AFASTYZFR1's Avatar
yea, and I pushed the cable back in while touching the line by the module and cable moves freely.....might get another unit and try it....
Old Sep 28, 2008 | 06:54 PM
Schnell's Avatar
did you check the 2 switches under the dash. I believe one is against the clutch pedal and the other is against the brake. Mine had broken of from the clutch pedal. It was a pretty easy fix with a zip tie.
Old Sep 28, 2008 | 08:38 PM
AFASTYZFR1's Avatar
yea....my clutch switch is there and adjusted properly......maybe the switch went bad...? I didn't check brake switch, but it must be working because brake lights work..... Also clutch switch must work because I can't start car unless clutch is in
