Oil Pressure Gauge Problem...HELP!
I have since drove the car the rest of the 1.5 hour drive back, as well as around town 2 times. And I have experienced no problems, other than the gauge acting weird.
I did just programmed my car with a Hypertech PowerProgrammer III, like 2 days before the 3 hour drive to home and back. So I reprogrammed my car back to stock, thinking this might be the problem...the SES light went off, however the oil pressure gauge still did the same thing.
So I'm wondering if it is safe to continue driving with this problem, or if I should bring it into the shop ASAP. I have a trip to a car show Saturday and need to know if I can go or not.
Thanks a bunch, and I really appreciate your help, as I am not all that smart with LS1's or cars in general.
Thanks,
Dustin
i'd do what conan said and check for oil pressure. if youre good then drive it until the light sets again and get it checked before you **** with the hypertech. that thing reset your PCM thus clearing the code. cant diagnose this until you know where to start.
Also I checked the oil and it was full and still very very clean...could the oil filter be plugged or just an old filter be causing this problem?
Thanks again for all your help.
Dustin
Now, as for the oil pressure. I would be willing to bet that the gauge has always acted that way, you just never noticed it until you started paying attention. If you used the hypertech while you had the SES light then you erased the code. The next time the code pops up, see what it is for.
To really check the oil pressure you would need to put a mechanical gauge where the oil pressure sending unit is near the back of the intake. But like I said what you've described sounds fairly normal. The pressure will be lower at a stop/idle and should increase when you get in it.
