Window motor Q install
I know there are limits to stop the window when it goes up but i don't think there are limits to stop it from going down.
So my Q is do you activate the motor while its off the gear on the window ( In your hand )to its full down cycle and then install it on the window gear?
Thanks
If you take the t top off does it look like it seals ok everywhere else? does it have a gap at the bottom?
You have been warned. I just when through this.
So the motor had some play in it and it mangled up the threads and made it harder to get off.
Ended up having to break the bolts off. Fortunately they were cheap china bolts.
