Problem with o2 sim..
Old Oct 10, 2008 | 06:30 PM
Nick98Z28's Avatar
Default Problem with o2 sim..
Here is my situation. Last year I had o2 sims on and passed my inspection..This year I went back twice to get it tested and failed both times. I started thinking the sims went bad because of a huge rainstorm i got stuck in last march. I bought new sims and put them on. took my car in for the inspection and since my guy is really cool he let me see the tester and i saw how there were 4 trouble lights flashing on and off so he tells me to drive for about 30 miles and they should go off. I do that, and got nothing. I start thinking it might be something electronic maybe the sims need to sync up. so i take my car home disconnect the battery and reconnect it. One of the warning lights went off leaving me with 3 still flashing. All i need is for one more of these damn lights to go out to pass! Can someone chime in with what the problem might be cause I did this last year and it passed the test with flying colors!
If it means anything I remember a couple of the lights flashing were the letter
C and 2E
Old Oct 10, 2008 | 07:42 PM
mvvette97's Avatar
you need to take it to a shop or someplace and have the codes read. From there you can fix the problem.
Old Oct 11, 2008 | 01:30 AM
CRAGER's Avatar
Administrator
Originally Posted by Nick98Z28
...so i take my car home disconnect the battery and reconnect it...
Thats another problem right there. Your PCM has to re-learn and can take around 30 miles or 30 minutes. It will fail in this re-learn mode I know this first hand.
Take your car to Autozone or where ever and have them scan it. Get the codes and look them up.
~ Craig
Old Oct 11, 2008 | 02:30 AM
00pooterSS's Avatar
~ Craig
It took me alot longer to get my car through relearn but I also had a bad cat which slows down the relearn, cats are one of the last things to go through relearn so once you get down to 2 not readys it will pass inspection, you ( OP )said you had 3 not ready so you are close.
Anytime you have something that is borderline on the relearn ( my cat in my case ) it really slows down the relearn, if everything is perfect it goes quick. Seen this on multiple vehicles of different makes and models ( im a tech )
