does the mufflex 4" mate right up to the ARH y pipe?
Old Oct 12, 2008 | 03:35 PM
94 guy's Avatar
Default does the mufflex 4" mate right up to the ARH y pipe?
or do i have to start bending and cutting?
Old Oct 12, 2008 | 03:42 PM
94'BLKBRD's Avatar
Im sure it will take some minor work for it to fit right.
Old Oct 13, 2008 | 12:26 PM
cals400ex's Avatar
does the mufflex bolt up to the stock y-pipe or do you need to run an aftermarket Y? the standard ARH Y will merge down to the same size as the stock Y so you can run any catback. now if you start custom ordering stuff then everything changes of course.
Old Oct 14, 2008 | 08:05 PM
studderin's Avatar
you can also get your ARH Ypipe for a 3 3.5 or 4inch Ipipe.
Old Oct 14, 2008 | 10:22 PM
DTB_LS1's Avatar
I asked the same question when I was buying my Mufflex system and the answer I got was, "As long as your aftermarket Y-Pipe exits in the same location as the factory you should be fine." If it helps any I ordered my 4" Mufflex system with a 4" to 3" reducer and it bolted right up to my pacesetter ory with no problems.
