Fitment Problem with QTP longtubes
Old Oct 31, 2008 | 08:54 PM
  #41
Sprayed 99's Avatar
Originally Posted by Golf&GM
I got the Fel-Pros from Advance, not sure if they are multi-layer or not but they are metal.
i'd go with gm mls gasket. they're reusable and imho they seal the best. as far as fitment on the passenger side i've seen a few threads on the issue and my set was real close to the k member too. you could grind the k member and get extra clearance too. all in all they are a real nice header. finish and welds are sweet looking.
Old Nov 1, 2008 | 10:05 AM
  #42
blown03mustang's Avatar
+1 no problems with my QTPs
Originally Posted by TheSilverOne
Pretty much with all headers motor mounts are a must. You're going from the tiny stock y-pipe to a 3" y-pipe. You want the most ground clearance possible so therefore the y-pipe is pushed up as close to the floorboard as possible. With the stock rubber motor mounts, when the engine torques over the y-pipe will hit the floorboard. With poly or solid motor mounts, the engine will barely move. I have no banging or clearance issues with my QTPs.
