Random pink wire....
Old Oct 16, 2008 | 03:19 PM
Das Korvin's Avatar
Default Random pink wire....
I am currently in the middle of my first spark plug and wire change. God help me.
However, that is not the problem. I just noticed a pink wire that had it's heat casing melted onto my AIR gasket. The wire came free pretty easily, but that is when i noticed it was REALLY loose. I pulled it up (pretty long wire) and it turns out to not be connected to anything. In fact, it looks like it was cut. I followed the other part and it seems to go into my fuel rail.
I attached some pictures. Anybody know what this wire is for? I am not experiecing any problems with the car, and God knows how long it has been like this.
Attached Thumbnails Random pink wire....-pict0027.jpg   Random pink wire....-pict0028.jpg
Old Oct 16, 2008 | 06:21 PM
TA-Swede's Avatar
That's odd. And spliced into the injector cables...
My guess is that a previous owner needed a tach-signal for something (nitrous?), and that's where he found it suitable to get it...
Good luck with the plugs.
Old Oct 16, 2008 | 06:26 PM
wickedbusa's Avatar
Plugs and wires aren't too bad on LS1's. Try plugs and wires on an LT1 and you'll see what I mean.
Old Oct 17, 2008 | 08:39 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
Looks like they had a remote start or other system installed the required some sort of RPM reference signal. With systems that only need a reference for what it should see at idle, actual RPM doesn't matter, so many people just use an injector wire instead or properly running it to the pcm.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Oct 17, 2008 | 02:55 PM
Das Korvin's Avatar
Well, I actually have a remote start system on it now. You think that has to do with it?
Old Oct 17, 2008 | 06:50 PM
Red96TA's Avatar
Oh man, that was without a doubt the best night of my life.
