Alternator: Look at this pic
My friend had a damaged wire, and it caused his voltages to read low all the time. Once we fixed it, his voltages returned to normal!
Ok here is how it actually works, checked into it today, the exciter only turns on the alternator the alternator is internally regulated, so the exciter DOES NOT affect output, Grimes what the case would have been with your buddies is sometimes the connection was good enough to excite the regulator, other times it wasnt, an intermittent connection is what it was. Yes it does supply power to the regulator to kick it on but then the alt takes over the regulation.
Wanna test the theory? Hook up a volt meter to the battery, get good acces to the wire to where you can unplug it while the car is running, or cut the wire and put a connector/ whatever you have to do to disconnect the "feed" to the alternator. Then start the car let it idle for a minute or so for the regulator to get going, then disconnect the wire, the voltage will still be up, turn on the lights and a/c at one time you will see the voltage drop and if the regulator is working it will pull the voltage back up to a steady level or close ( seen this on countless cars as a tech, that were not PCM regulated )
Hope this helps guys.
OP post up when you fix it so we can learn from it bud. Even if you post up we were all wrong or what have you. Or do you have any updates yet? Tried swapping batteries between your cars yet or putting a voltmeter on it to confirm your guage?
