Just installed SLP UD Pulley... PITA!
I really like my pulley and am glad that I got it. Prior to putting it on I had a new stock balancer that I had balanced at a machine shop. With the powerbond the engine runs smoother. There is a lot less load on the engine at idle. The engine accessory drive is quieter because of this. It also makes tuning the idle on a big cam easier and allows you to idle at a lower rpm.
For a puller I have the bluepoint 3 jaw made for these type pulleys. It works perfect and is durable. For the installer I have a longer high grade bolt, a washer, and a bearing. Works great too.
