Single vs Double Roller?
Old Oct 22, 2008 | 11:09 AM
deuce4935's Avatar
Exclamation Single vs Double Roller?
Does using a double roller timing chain on an LS1 require machining of the block or shimming? I'm just trying to figure out whats best for a mild street cruiser/brawler.
Old Oct 22, 2008 | 11:21 AM
mr. Jones's Avatar
you shim the oil pump, shims should come with chain.
you also should cut about 1/8" wide by 1/16" deep chamfer on the rear of the balancer collar. this provides more clearance for the chain. CHECK THOSE DIMENSIONS.
no block machining required.
Old Oct 22, 2008 | 11:49 AM
on2's Avatar
on2
LS2 single chain. Research it. Many people go this route.
Old Oct 22, 2008 | 12:09 PM
silverLSWON's Avatar
hands down ls2. but use the ls2 sprockets and chain. some people just use the chain but for 70 bucks....get the whole thing new. double roller is a little over kill unless you build a CRAZY high hp motor. you don't have worry about shims or grinding your timing chain cover(in SOME cases).
Old Oct 23, 2008 | 11:25 AM
Raise's Avatar
You will need to shim the oil pump with the double roller. But as already stated, research the LS2 singl chain. It has withstood some serious hp applications.
Old Oct 24, 2008 | 12:04 PM
BETTER THAN YOU's Avatar
ls2 all the way
