Installed ported tbody now P0122 code?
Old Oct 23, 2008 | 06:34 PM
adam02gt's Avatar
Default Installed ported tbody now P0122 code?
I installed my ported tbody and the idle has been surgung sporadically and has now thrown the code P0122(tps voltage low). Any ideas?
Old Oct 23, 2008 | 06:37 PM
Damian's Avatar
LSX Mechanic
Sounds like your porter either went passed the blade a tad too far, or if the blade is "knife edged" that can do it as well due to material being taken off the blade.
Old Oct 23, 2008 | 07:08 PM
adam02gt's Avatar
The blade is untouched. And I tried loosening up on the tps a little bit to see if that helped so we'll see I'm gonna go drive it now.
Old Oct 23, 2008 | 07:49 PM
zracer323's Avatar
It could be because of the bumpstop shaved down too far. If you go past 90 it will throw a code. Just a guess
Old Oct 23, 2008 | 11:11 PM
Damian's Avatar
LSX Mechanic
That won't cause an idle issue. That will throw a TPS voltage code @ WOT.
That's not gonna do it brother. Sounds like they ported too far past the blade which isn't repairable.
The good news is however you can sell that TB to somebody with a heads/cam car and/or bigger motor and it'll be fine. Get yourself another stocker and get it redone.
Old Oct 24, 2008 | 10:33 AM
Muerte_X's Avatar
You could try plugging the hole in the blade with a tiny nut & bolt. This worked for a friend when his was ported too much.
I'd be very careful though, whatever you put on there needs to be on there very securely. You don't want a screw or putty or something going into your engine.
Also, make sure everything is installed correctly, when I first put mine on it did the same thing because of a vacuum leak because i didn't have the throttle body tightened down enough.
Old Oct 25, 2008 | 12:55 PM
adam02gt's Avatar
Well I got it fixed I believe. HPtuners kicks *** lol....
Old Mar 3, 2009 | 03:17 PM
69_YENKO's Avatar
What did it end up being? I also have this issue and HPTuners if that helped with your fix
My problem comes after a swap to heads/cam, fast 90/90 with a TPIS TB
