LS6 intake worth it?
Old Nov 2, 2008 | 10:55 AM
thebulgd's Avatar
if you're not doing any other mods I would say no, its not needed. I had the LS1 intake !air and switched to the LS6 intake and didnt notice anything, bolt-on A4. The LS6 intake isnt going to hurt at all, I just wouldn't expect much gain.
Old Nov 2, 2008 | 11:37 AM
jrob56's Avatar
i will be making the switch in the spring hopefully, my car and my friend's have an identical setup besides his ls6 intake and a tune and lets just say it made me feel that waiting to get the ls6 then tuning is worth it...
Old Nov 2, 2008 | 04:15 PM
ls1jim's Avatar
Definitely worth it once of the first things i did
Old Nov 3, 2008 | 09:16 AM
99_SS_LS1's Avatar
Originally Posted by Firehawk#286
Current mods are in my sig. Honestly, don't see any other mods in the future...at least not for this car (except maybe a tune). Stock cam is staying in, as there's no $$ for another. I'm after a little more hp and tq, but this car will never see the track, and top end (over 6k rpm) is out of the question. So, would a LS6 intake be worth it for ME?
Nope not worth it for you. You'll gain more from a tune than you will from the ls6 intake.
Old Nov 3, 2008 | 11:32 AM
jrob56's Avatar
But hell gain more from his tune with an ls6 intake, its not an either or situation it makes sense to get the intake and then tune so you dont have to redo it later if you change your mind. it sound like you want to get all you can as cheaply as you can without going internal. i would do the intake and a tune and it sounds like your done...
Old Nov 3, 2008 | 02:04 PM
99_SS_LS1's Avatar
Probably true. Although I had headers, catback, lid, cam and tune, then afterwards decided to do ls6 manifold and saw no gain. Granted it was on two different dynos, but the first one was a mustang, the second a dynajet.
And like someone mentioned previously, has a larger plenum, which makes gain only in high rpm...
I'm not saying it's a bad mod, just not sure it's everything everyone on here has it cracked up to be.
Old Nov 3, 2008 | 03:36 PM
LS1-450's Avatar
Another argument demonstrating that dyno's are for tuning & not for proving or diss-proving single modifications.
Old Nov 3, 2008 | 06:18 PM
its turbo time's Avatar
Originally Posted by c5z28
Just something to tease yourself about but they have used baby cam setups for sale for around the same price and you can actually expect to see power gains under the curve like 20rwhp and up.
I thought you were never supposed to run used valve train parts in a different car?
Old Nov 3, 2008 | 06:20 PM
Originally Posted by LS1-450
1)Valves are closed. There is no PTV clearance issue.
2)Maybe, depends on what you buy.
3)Yes, as noted originally
4)I tune on the street w/ EFI live. Further, a dyno would prove nothing. Too many Dyno variables involved when trying to measure a single mod like rockers. I could do nothing to my car & pick up 8 to 9 HP on a different day on the same dyno.
Yes, the airflow increased after adding 1.8's to my mild cam. I can log airflow w/ EFI Live. IMO, 1.8 rockers are a good way to to help small cams when the owner doesn't want the hassle of doing a swap "for small or stock cams ONLY." The rockers don't have to cost $500 either.
I stand by my statement that an LS6 intake & properly installed 1.8 rockers will wake your car up w/ less hassle than a cam swap.
How much power will a RR and ls6 wake a car up?
Old Nov 3, 2008 | 06:59 PM
jrob56's Avatar
there are a lot of people in trouble on this board if that is true
Old Nov 3, 2008 | 08:36 PM
LS1-450's Avatar
Can't answer that. It depends on too many variables. I can say that it will increase power. Increased &/or less restricted airflow + greater valve lift = more air entering the combustion chamber. After tuning for the air increase, power is increased.
Here is an example of some mods & how my car benefitted: (As noted earlier, I can log airflow).
After adding a Weiand intake, heads, mild cam, 1.8 rockers, & 85mm TB my car moved 27% more air than when it had stock intake, cam, rockers, TB, long tubes, & true duals.
After then shortening the length of the cold air intake & adding an 85mm MAF, gained another 3% of airflow.
Old Nov 5, 2008 | 02:45 PM
  #32
wilddawg's Avatar
see more with a underdrive pulley than the intake
Old Nov 5, 2008 | 03:15 PM
  #33
67SS&99SS's Avatar
When I installed mine, I definately noticed a seat of the pants difference. I carried it out a day before I did the swap and a day afterwards. When it got to about 3500 rpm I could feel it pulling harder, and it did better all the way to the redline. Down low I actually felt a little bit of a loss, but that is to be expected with the larger runners/volume of the intake. Its definately cheaper than a fast setup. I couldn't justify spendng 900 on a intake and another 300 on a tb.
Old Nov 5, 2008 | 03:29 PM
  #34
Chace02ws6's Avatar
I would definately hold off and save your money for a fast setup, You maybe happy with your ls6 intake at first, But if your like me then you always want bigger and better. Save and go with the fast
Old Nov 5, 2008 | 03:57 PM
  #35
khaotic's Avatar
Default intake testing results
Dont know if this will help you out but here is some intake and throttle body testing and results.
http://www.tpis.com/index.php?module=2_17_06
Old Nov 5, 2008 | 04:10 PM
  #36
bigti99a's Avatar
you can easily make over 400+whp through the ls6, if that is what your looking for then great. if you are going bigger than get the fast. just my .02
Old Nov 5, 2008 | 04:26 PM
  #37
johnLs1camaro's Avatar
when i did mine i felt a noticable difference, but i also had a cammed car that got choked with the ls1 manifold, but the ls6 did help it breath a lot.
Old Nov 5, 2008 | 04:42 PM
  #38
smok'nZ's Avatar
MASS seller approved
buy the ported one rite now and get a good 20+ gain
