LS6 intake worth it?
Old Oct 31, 2008 | 10:41 PM
Firehawk#286's Avatar
Default LS6 intake worth it?
Current mods are in my sig. Honestly, don't see any other mods in the future...at least not for this car (except maybe a tune). Stock cam is staying in, as there's no $$ for another. I'm after a little more hp and tq, but this car will never see the track, and top end (over 6k rpm) is out of the question. So, would a LS6 intake be worth it for ME?
Old Oct 31, 2008 | 10:46 PM
twitchtwice's Avatar
yes i say its worth it. for around 300 bucks used you can get about 10-15 with your current mods. its worth it.
Old Oct 31, 2008 | 10:49 PM
Slvr00Bird's Avatar
+1...
Old Oct 31, 2008 | 10:52 PM
Mean87SS's Avatar
Yes, it is.
Old Oct 31, 2008 | 10:58 PM
Swaie's Avatar
I just got one of guy on here cant wait to put it on.
Old Nov 1, 2008 | 12:37 AM
ae13291's Avatar
i just shaved the ribs on mine prepping it.
Old Nov 1, 2008 | 12:53 AM
c5z28's Avatar
I'll go against the grain and say no. I don't see why you would put all that stuff on if your not going to the track or race it I only picked up 6rwhp from my ls-6 and that power only comes in from 3k on up. Also your going to have to fork out around 400 for another tune (also get rid of the egr codes). If you change your mind wait to put everything on at once.
Old Nov 1, 2008 | 06:14 AM
LS1-450's Avatar
Yes, on the LS6, some 1.8 roller rockers for added valve lift, a tune & she'll wake right up. Just make sure that you understand how to properly install the rockers w/ the proper length push rods or have it done @ a shop. Good-luck
Old Nov 1, 2008 | 09:35 AM
---deleted---
Old Nov 1, 2008 | 09:39 AM
---deleted---
Old Nov 1, 2008 | 11:11 AM
TheBlueKnight's Avatar
I just talked to the owner of a local shop in Sacramento because I told him I wanted to get the LS6 intake and a tune. He told me that he really suggests I get a FAST 78mm intake manifold becuase they do a lot of f-body work and really only see minimal gains with the LS6.
Old Nov 1, 2008 | 12:31 PM
bczee's Avatar
I would look into a good Cat Back exhause system.. then maybe a LS6 intake.. if your looking for more.. maybe Headers (if you can get by the smog laws). A good tune.
These simple bolt on and a tune will help a stock engine the most and keep everythinig driveable and reliable.
Old Nov 1, 2008 | 12:34 PM
HMERacing's Avatar
Originally Posted by Firehawk#286
Now this is a very interesting idea...1.8's huh? This raises a few questions (without having researched this):
1) Piston-to-valve clearance problems?
2) Rocker-to-valve cover clearance probs.?
3) Tune necessary for this mod?
4) Any dyno results proving gains for this mod alone?
Do a search. there is another thread on this subject. I think he had speed inc.
install SLP 1.85 RR's and picked up something like 8 or 9 horse. he was not pleased. they are not worth it in my opinion. Too much $$$ for that little gain.
I would do a mild cam before I spend $500+ on RR plus installation.
Old Nov 1, 2008 | 12:36 PM
if you look in his sig he already has all of that.
Old Nov 1, 2008 | 01:51 PM
LS1-450's Avatar
1)Valves are closed. There is no PTV clearance issue.
2)Maybe, depends on what you buy.
3)Yes, as noted originally
4)I tune on the street w/ EFI live. Further, a dyno would prove nothing. Too many Dyno variables involved when trying to measure a single mod like rockers. I could do nothing to my car & pick up 8 to 9 HP on a different day on the same dyno.
Yes, the airflow increased after adding 1.8's to my mild cam. I can log airflow w/ EFI Live. IMO, 1.8 rockers are a good way to to help small cams when the owner doesn't want the hassle of doing a swap "for small or stock cams ONLY." The rockers don't have to cost $500 either.
I stand by my statement that an LS6 intake & properly installed 1.8 rockers will wake your car up w/ less hassle than a cam swap.
Old Nov 1, 2008 | 02:17 PM
c5z28's Avatar
That's what most people say about the fast 78 minimal gains over the ls6 they have a few threads that compare all the manifolds. For the money it will cost you better off getting the weiand if it ever comes out.
Old Nov 1, 2008 | 02:19 PM
c5z28's Avatar
This was sort of my line of thinking too. By the time I've spent $300 for the intake, and another $50+ for the two coolant lines (I wouldn't plug my back ones), I wonder if the hp/$ is worth it. I also understood from a couple of other posters in another thread that, if there is any noticeable increase in hp/tq, it's in the higher rpm's only (where I probably will seldom if ever see it).
Btw, I haven't tuned my car yet, since installation of LTs, ORY, and deletion of EGR/AIR. I was waiting to see what other mods I might want to do....so I could pay for a tune only once.
Just something to tease yourself about but they have used baby cam setups for sale for around the same price and you can actually expect to see power gains under the curve like 20rwhp and up.
Old Nov 1, 2008 | 02:21 PM
Detoxx03's Avatar
If your not gonna do any serious mods then get it but if you decide to go h/c you will need a fast intake
Old Nov 1, 2008 | 02:29 PM
c5z28's Avatar
One more thing first link tells you the dangers of the opsu even after reading this you still will probably brake it.
https://ls1tech.com/forums/showth...=967733&page=2
2nd link shows a picture where you chisel off the fins of the ls-6 so you don't have to spend 50 bucks to get the new steam lines
https://ls1tech.com/forums/showth...065&highlight=
Old Nov 1, 2008 | 05:21 PM
---deleted---
