Still no SES Light
Old Nov 4, 2008 | 09:10 PM
jrpimp00's Avatar
Default Still no SES Light
Its been almost 3 weeks since my LS6, LTs, !Air, !Egr, install and still no light. I put over 170 miles on the car and the day before the install I had my NC Inspection done and no problems. Car runs real good, no problems at all. Any thoughts on why I havent had a light. Anybody else ever have this happend. I just want to make sure my car will be fine when I do my tune.
Old Nov 4, 2008 | 09:40 PM
fuseone's Avatar
were you the only owner if not maybe some one just got it done before plaining to do the install.
Old Nov 4, 2008 | 09:42 PM
jrpimp00's Avatar
3rd owner car was completly stock, except for Fast 78 TB
Old Nov 4, 2008 | 11:05 PM
noriceinside's Avatar
when you turn you key on does the engine light illuminate for the bulb test?
Old Nov 5, 2008 | 02:59 PM
jrpimp00's Avatar
Just went and checked it and nope not showing it lighted at start up, I got a scanner and its not showing any codes, what do you think is wrong
Old Nov 5, 2008 | 04:44 PM
jrpimp00's Avatar
Just checked again sometimes it comes on sometimes it doesnt. I hook my scanner up tp it and it can read everything and no codes are shown
Old Nov 5, 2008 | 05:46 PM
Unertl42's Avatar
I guess I'd be happy if my car's SES light didn't come on
Old Nov 6, 2008 | 10:06 AM
00_transam_vert's Avatar
Not really man, that SES light can prevent you from doing real damage if somthing goes wrong. If its not working properly I would deffinantly wanna know.
Old Nov 6, 2008 | 10:36 AM
jrpimp00's Avatar
Still the same thing it'll do the bulb test on the SES sometimes. Like I said i can run a diagnostic on my laptop and everyting comes back ok. But I cant even make it throw a code. I trie unplugging MAF, TB sensor, etc, still no light
Old Nov 6, 2008 | 11:14 AM
wow, thats pretty fucked up maybe the previous owner did the super computer mod? or maybe your car is a transformer, does it ever disappear during the night?
Old Nov 6, 2008 | 12:43 PM
cowboysfan's Avatar
you should only need to turn key to run and SES should be on. once the engine is started the SES light turns off about a sec later. I wouldn't worry about it if it does come on with key turned to run but engine not running.... as for the fast tb I would say it had to be tuned for that or the guy removed the bulb....
Old Nov 6, 2008 | 09:36 PM
GM WORLD CLASS's Avatar
take it to a chevy/pontiac dealer and have them flash the pcm from tis2web. this will restore its stock programming and eliminate the pcm tuning as a possible cause. they probably wont charge much to do it.
