Fuel pump install ? (pics)
Old Nov 5, 2008 | 05:32 AM
socmguy's Avatar
Restricted User
Default Fuel pump install ? (pics)
I'm having trouble installing my new fuel pump. I've got the assembly out of the tank and have the pump installed with everything but the venturi tube. In the pictures you can see the long brown tube. In stock pump, there's a brass fitting that the tube slides over. On the new Wahlbro pump, there's no fitting, just a dimple. For those that have done this before: do you just push the venturi tube into that hole? I hope the pics help, thank you.
Old Nov 5, 2008 | 01:17 PM
Super Speed's Avatar
The walboro doens't use the Veturi system so you will have to cut the bottom of the bucket and keep your fuel levels above 1/4 tank. The other option is a racetronix fuel pump
Old Nov 5, 2008 | 06:19 PM
ae13291's Avatar
dude if thats true, screw the walbro i would get the racetronix for sure
Old Nov 5, 2008 | 07:23 PM
socmguy's Avatar
Restricted User
Cut a hole in the plastic bucket?
Old Nov 5, 2008 | 07:35 PM
SS1875's Avatar
Maybe this will help you out.
http://gonicd.com/intankinstall/intankpumpinstall.html
Old Nov 5, 2008 | 08:05 PM
ae13291's Avatar
would the racetronix fit into the bucket?
Old Nov 5, 2008 | 08:43 PM
SS1875's Avatar
I have a Racetronix in mine......so yes.
Old Nov 5, 2008 | 08:53 PM
ae13291's Avatar
what is the differance between the kit with all that wiring and the ones where its only the pump? i thought it was just R&R
Old Nov 5, 2008 | 09:04 PM
SS1875's Avatar
Read the following and as it explaines it better than I can.
http://www.racetronix.com/RX-F99-FPKG-2.html
Old Nov 5, 2008 | 09:26 PM
ae13291's Avatar
thats real great! looks like i will be upgrading with the harness and pump. what do they mean with the factory ground not being good? which grounding points? i have added additional grounding wires to my car but i dont know if there the points at which the car has weak ground at?
Old Nov 5, 2008 | 10:06 PM
socmguy's Avatar
Restricted User
FUCKKKKKKKK!!!!! I'm so ******* pissed off right now!!!
I bought the whole pump kit from someone on a local board in May. I had the entire Racetronix kit sitting in my garage until now. My plan was, when I get a rear, I would pull my tank at the same time and install my pump. The time has finally come and I have bought a Moser 9". My rear is on the garage floor and the tank is down and opened up. Go to put the pump in and there is a piece of **** USED Wahlbro, in a goddaammn Racetronix sleeve in the bag. No ****** wonder it wouldn't go in and didn't have a venturi port! Now my fuel tank is sitting on my garage floor and I have the entire Racetronix wiring harness and Ground and the wrong ******* FUEL PUMP! I just PM'd the guy and he better make this right or I'm going to be really upset! For a new pump only, it will be another $150 from Racetronix. ****!!!
Old Nov 5, 2008 | 10:10 PM
ae13291's Avatar
damm man sorry to hear. hope everything works out
Old Nov 6, 2008 | 12:35 PM
socmguy's Avatar
Restricted User
I talked to the guy I bought it from and he got it from someone else. This really puts a bad taste in my mouth because I can't get mad at him if he didn't know it was junk. **** MAN!
Old Nov 6, 2008 | 08:25 PM
wht01ws6ta's Avatar
That sucks man, sorry to hear that you ended up getting a different part than what you paid for/thought you had. Are you going to buy the racetronix pump only?
Old Nov 6, 2008 | 08:31 PM
ae13291's Avatar
then return it back to him. its his fault for not knowing what part he got and advertised it as something different. send it back to him
Old Nov 6, 2008 | 09:27 PM
wht01ws6ta's Avatar
This is true.
Old Nov 7, 2008 | 08:51 AM
socmguy's Avatar
Restricted User
That's a good idea ae. I'm going to contact him and see if he'll take it back.
Brandon
Old Nov 7, 2008 | 09:15 AM
metalmechanic's Avatar
i know what you are going through, i did the fuel pump years ago on my 96 fire bird, i did the complete job 4 times before everything was just right, the crappy pump from oriellys didnt even have a cradle for the pump to sit in, so i got a ac pump, changing fuel pumps sucks
