Pro products Typhoon Intake Manifold
it. No leaks or anything, a few things to get past on the install
(valley cover bolts, extend MAP pigtail) but no show stoppers.
I just wanted to get rid of plastic primarily. But will see what MPH
does, one of these weeks.
What's junk about it? the only thing I've seen is the gaskets
& fittings were updated, and the valley cover bolt head height
can interfere. One solved for you, one costs about 10 bucks for
new bolts.
Plenty of material to open the snout that little bit, for a 100 even better.
This car is a stock 98 botton end, 98 port heads, and Futral 13.5 cam or whatever they called it....oh, and with 120+k miles....
HERE IS A LINK TO MY INSTALL THREAD
The Futral has more lift and more duration than the Vinci...depending on which 113 cam they used, it can be as little as .040" more lift, or as much as .090"+ more lift, which will surely have raised the dyno numbers by themselves.
Not saying the intake isn't working, but those results tell us nothing.
