Rear out of 3rd Gen???
if you guys could help me on this... https://ls1tech.com/forums/gears-axl...l-spacers.html
the 19x10 corvette C6 wheels like i have would need a 2.5" spacer or so to work with 3rd gen wheel
Z06 replicas should be 18x10.5 or so? they will need a 2" but you can measure the offsets/backspacing to get a better idea. If they fit just fine now with the 4th gen rear, figure the rear is narrowed about 1.75-2 inches per side, so you will need a 1.7 to 2 inch spacer
BOLT on spacers are VERY safe. Lugs support the spacer and the spacer has its own lugs for the wheels. SO its just a stock extension. Use ARP wheel studs to be sure you have strong connection if your worried
You'd have to measure this to be sure, but you probly would need a 15x10 with thirdgen backspacing to fit like stock. It just pushes everything 2" closer to the inner fender well. Its nice since they make some wide rims with smaller backspacing specs that wont normally fit on a 4th gen car without a narrowed rear
SO buy a thirdgen rearI'm doing the opposite, i'm getting a 4th gen spec rear to keep my 4th gen wheels
To the OP, the 3rd gen rear is 3.5" shorter than the 98-02 rear, and 4" shorter than the 93-97 rear. The 3rd gen rear also has no provisions for either ABS or traction control, however you can modify it to accept an ABS sensor. You will have to modify the axle tube ends to swap your disc brakes over.
i measured my rear and this one and its exactly 3 inches narrower, i bought 1.5 inch spacers and will be installing the rear tomorrow...
ill be grounding he 3 wires at my abs box so bye bye ABS/TCS/ASR
it came with lt1 brakes, backing plates and calipers, so ill jsut sway the disks for my ls1s for the ebrake...
if anyone else has a question, i think ill have your answer...
again 3RD GEN REAR IS EXACTLY 3 INCHES NARROWER THAN LS1 REAR
im glad you got your rear fixed.
