Descreened Maf or 85mm Maf conversion?
years. Was pretty dead-on for accuracy (using
truck MAF table) until I did the cam & intake, now
it's a bit off. Not enough to spend the time retuning
it though.
If you still have a stock diameter throttle and no
big motor mods then I'd recommend just descreening
the stocker. The remaining pressure drop will not
matter. I gained nothing from going to the 85mm
at the time (had already descreened the 75mm).
That was on a 440rwhp h/c/i stock cube car.
As I recall, I used the maf tables from an '03 vette, and modified the table by 6% across the board. Put it on the dyno and had it professionally tuned, very little needed to be done to the maf tables. Don't quote me on the 6% though.
and you can pop the screen without fear of
damaging the sense elements. Setting the
nose piece in a dish of paint remover overnight
makes the screen just about fall out, so you
will have it intact if you cared to go backward.
When I descreened mine I used the nose off
a donor and kept the original.
You can use the stripper-soak on the 85mm too
as long as you keep it shallow enough not to
touch the plastic part. My 85mm was tougher
to descreen and I had to hurt the honeycomb.
