how do you hook up a wideband on TDs?
Old Nov 14, 2008 | 01:48 AM
OMGls1jz's Avatar
Default how do you hook up a wideband on TDs?
hey guys i'm wondering how would you hook up a wideband with a single sensor on a TD setup? i've searched and nothing came up. would you have to have two separate widebands? or could you some how merge two sensors into one wideband? i'm asking because i have a friend that has hp tuners and is willing to do a street tune for me but i don't know if i need to put the wideband on just one side or both. LMK guys.
thanks, toua
Old Nov 14, 2008 | 06:28 AM
LS1-450's Avatar
Pick a side.
Old Nov 14, 2008 | 07:34 AM
LPTXZ28's Avatar
I have mine in the driver's side and it is working great.
Old Nov 14, 2008 | 07:55 AM
00SSLS1's Avatar
on the x, j/k pick a side
Old Nov 14, 2008 | 10:11 AM
OMGls1jz's Avatar
so it doesn't matter what side it is?
Old Nov 14, 2008 | 06:05 PM
TheSilverOne's Avatar
drivers side, it runs leaner than the passenger side.
Old Nov 14, 2008 | 06:07 PM
Z28M6TT's Avatar
technically all 8 cylinders are gonna have a slightly different A/F, so you basically just picking which 4 your going to monitor.
Old Nov 16, 2008 | 07:59 PM
OMGls1jz's Avatar
okay, i'll pick the driver side i guess.
Old Nov 19, 2008 | 12:06 AM
JonCR96Z's Avatar
It's no different than a y pipe setup. It should in as near the collector as possible just like the factory ones. Driver side bank is supposed to err more on the lean side, so it's the better bank to have the wideband.
Old Nov 19, 2008 | 10:16 AM
OMGls1jz's Avatar
k thanks
