? for people with hooker headers
Old Nov 14, 2008 | 03:52 PM
firehawk88's Avatar
Default ? for people with hooker headers
I wanted to know what you guys are doing to help with spark plug wires going bad on the #3 cylinder? On my 02 Camaro my stock plug wire finally deterated from the header basicaly smashed right up against the plug wire. Will a aftermarket set fix this or is it something that i will have to deal with and keep buying new wires? What's the best brand that you guys have had good luck with. Thanks for the help.
Old Nov 17, 2008 | 03:31 PM
Taspeed's Avatar
i've got the 10.8mm thundervolt wires and don't have a problem
Old Nov 17, 2008 | 04:50 PM
12secSS's Avatar
I run Kragen brand and have no problems. I used to use MSD, but they touch the priamry and burned through. I also tried Taylors, but those fell apart when I remove them. Never had an issue (other then MSDs) of wires touching the primaries with my Hooker Headers.
