LS2 243 heads onto LS1
Old Nov 14, 2008 | 08:36 PM
PowerTalk's Avatar
Default LS2 243 heads onto LS1
Ive heard two different stories with putting LS2 243 heads onto a LS1 with stock 853 heads.
First one is that they bolt onto an LS1 block fine with no issues.
Second one is that they have a different bolt pattern and dont line up?!?
So who is correct?
The other thing, is the only difference between them is the sodium filled valves in the LS6 243s!?
I have searched but have still see both things written
Thanks
Old Nov 14, 2008 | 08:50 PM
bluebird00's Avatar
the ls2s should bolt right up to a ls1 block,cause im getting ready to install a set on my ls1.
Old Nov 14, 2008 | 08:54 PM
PowerTalk's Avatar
Perfect
Can you give us some feedback when you're done?
Old Nov 14, 2008 | 09:01 PM
s/c'd cav's Avatar
only thing i know different is the rocker covers on early LS motors are perimeter bolt and newer are center bolt(LS2)
and the head bolt heights are different on a couple bolts
Old Nov 14, 2008 | 09:52 PM
PowerTalk's Avatar
I wonder whether people are getting confused about valve cover bolts instead of head bolts?
Old Nov 14, 2008 | 09:57 PM
thegroup's Avatar
after 1999 (i think), the vavle covers went to center bolts b/c my 2000 has them. i honestly dont know about the bolt pattern but everything ive seen on the net, any LS-series will interchange with the others. dont quote me on it though
Pro52R's Avatar
Geezus christ..
a search could have saved some bandwith
Old Nov 14, 2008 | 11:57 PM
PowerTalk's Avatar
Originally Posted by Pro52R
Geezus christ..
I did
There's conflicting answers if you search!
Old Nov 15, 2008 | 12:05 AM
cabech984's Avatar
The heads will work on your engine. However, if you have perimeter valve covers, youll need to switch to centerbolt covers and their coil packs & brackets. If replacing head bolts, get the ones for your style of engine block because they made different styles for different engine blocks. A set of ARP Head Bolts(6 point) for an LS1 Fbody(or 97-03 LS1/LS6) blocks will cost you $150 from most of the vendors.
That is what you need to know.
Old Nov 15, 2008 | 12:07 AM
NemeSS's Avatar
ls2 heads will bolt to ls1
only 02-04 zo6 came with sodium filled valves
243 are found on many cars, not limited to ls2
2.00 intake valve 210cc runner
1.55 exhaust valve
D shaped exhaust ports
65cc chamber
Old Nov 15, 2008 | 12:22 AM
PowerTalk's Avatar
Thanks guys
Old Nov 15, 2008 | 01:56 AM
jsteele90's Avatar
how can you tell what year 243 heads you have
Old Nov 15, 2008 | 07:11 AM
Summerwolf's Avatar
I swapped 2006 GTO heads (243) onto my 2004 GTO (241) without any issues whatsoever.
Old Nov 15, 2008 | 07:40 AM
redtail2426's Avatar
they are on my ls1,no issues.As long as you have centerbolt valve covers now then its a direct swap.if not you will just have to get a set of centerbolt valve covers and the coil pack hardware.
Old Jan 31, 2009 | 07:17 PM
FiredUpZ28's Avatar
are you guys putting these heads on as they came stock or are they getting ported first?
Old Jan 6, 2011 | 09:13 AM
ls1jorge's Avatar
Srry to bring up a old thread, but I'm in the process of buying stock 243s, how much of a gain would it be over the 853 stock heads??
Old Jan 6, 2011 | 09:27 AM
bayer-z28's Avatar
^ Maybe 15hp. 853's are pretty much the bottom of the barrel. I've got an old set hanging around.
Old Jan 6, 2011 | 10:04 AM
ls1jorge's Avatar
Yea how much you want for 243? & complete??
Old Jan 6, 2011 | 11:58 AM
bayer-z28's Avatar
^ They're stocker 853's.. not worth much. Was asking $175, but I could prolly get that by selling em for scrap metal. They're as good as a paperweight, IMO. You can get 241's for the same price and a slightly better head. Yeah, they're complete.
You looking for a budget build? I got my P+P'd 243's off an 04 ZO6 for $600 new and assembled, but with stock springs.
Old Jan 6, 2011 | 12:02 PM
jimmyblue's Avatar
Moderator
That's what's on mine - home ported GTO (LS2) heads.
No prob.
