thermostat
Old Nov 21, 2008 | 07:43 PM
gsxrfarm's Avatar
Default thermostat
ok guys well i took off my water pump to put on my new one witch is not cheap lol but i found that my thermostat had some kinda rubber type o ring laying on it half attached and half not. so i guess i will have to get a new one? what degree should i get? i will be running it both street and strip so if some one could explain the diff. in a stock one and a 180 witch will help with power the most thanx
Old Nov 23, 2008 | 09:45 AM
teke184's Avatar
if you have it out, def put in a 160. engine will run cooler and you'll have less chance of detonation.
won't be a huge gain in power, but every little bit helps.
Old Nov 23, 2008 | 11:00 AM
HMERacing's Avatar
just replace the oring
