P0135 p0155 p0102
Old Dec 3, 2008 | 12:12 PM
slohemi's Avatar
Default P0135 p0155 p0102
Ok so im throwing 3 codes, P0135 and P0155 are for the front 02 sensors. P0102 says the PCM has determined that mass air flow input is lower than expected for the current engine operating conditions. My car seems to be down on power and it idles all over the place. Im pretty sure there are no vaccum leaks, MAF and MAP are both plugged in. What could be going on? Could the 02's be causing my rough idle thus throwing the p0102 code?
Old Dec 3, 2008 | 01:42 PM
2001NBMZ28's Avatar
Is it also harder to get the shifter over to reverse? Check the ENG SEN fuse - MAF, 02's, skip shift and reverse lockout are all on the same circuit. Something easy to check.
Old Dec 3, 2008 | 01:58 PM
slohemi's Avatar
Yes the car is hard to get into reverse..i posted a thread not to long ago about that. Also was throwing a code for skip shift as well. Thanks man ill go check that out.
Old Dec 3, 2008 | 02:26 PM
2001NBMZ28's Avatar
If it's blown check for an 02 harness hitting the LT's somewhere.
