P&p throttle body
Old Dec 3, 2008 | 12:43 PM
2000Z-28's Avatar
Default P&p throttle body
Going to p&p my throttle bodle to night u guys got any tips for me thanks
Old Dec 3, 2008 | 01:45 PM
04600rr's Avatar
search for port and polish..there is a ton of DIY stuff out there....
Old Dec 3, 2008 | 02:16 PM
Red99TA's Avatar
Yeah, don't port near where the butterfly rests when it's shut...if you do then too much air will bypass the blade and your car will idle too high. Also don't get too greedy sanding down the "hump" or you can break through to the outside of the housing then you're stuck using JB weld to fill the hole. Last thing is if you're doing the bump stop mod then don't allow the blade to open more than 90 degrees or you will trip a TPS error and corresponding check engine light. It's really not a difficult trade to master it just takes time and a steady hand. I've ported/polished around a dozen of these things.
Old Dec 3, 2008 | 02:42 PM
2000Z-28's Avatar
Thanks
Old Dec 3, 2008 | 03:33 PM
bene's Avatar
Trunion King
Its soo easy a caveman can do it.
Old Dec 3, 2008 | 04:30 PM
Damian's Avatar
LSX Mechanic
Its BODY not "bodie"
I fixed the spelling in the title of your thread to reflect that you actually know how to spell correctly
