JAAM vs. current setup?
I was looking at the JAAM ram air from FTP, but I'm not sure if I want it. It looks a lot nicer than mine.... since mine is kinda duct taped in currently... lol. And it uses all four nostrils instead just the two upper ones like mine. But at the same time, mine is completely sealed, and theirs has three big holes cut in the metal bottom plate... so I don't know.
What do you guys think? Thanks
There is more info you can read about the kit on our web site:
http://fasttoys.net/shop/product_inf...oducts_id=1475
The JAAM kits are on sale right now through our web site or you can call us at 877-955-4896. The sale will be ending soon so you get your kit if you want one
Thanks!
JAAM did a lot of testing when they developed the kit and found a significant increaes in performance when using the bottom plate in conjuction with the top portion. There is no way to seal the bottom nostrils to the air box so the deflector plate was the next best thing.
Let me see if I can explain it better. The kit comes with seals that go around the top nostril opening on the underside of the hood. These seals go up against the top and left and right side of the air box when you shut the hood. When closed, the front of the air box is still open towards the bottom to allow air to come in from the lower nostrils. The lower deflector plate installs in front of the air box to provide a path from the lower snorkils into the front of the air box. This allows both nostrils to feed the air box at the same time.
Hope that makes sense!
Anyway, how long is that sale of yours going to be going on?
JAAM found the air pressure was improved with the lower deflector in place vs. just using the upper nostrils.
Manufacturers do lots of things to decrease the cost of warranty related work which costs them money in the long run.
Thanks
Larry
