I fought the car, and the car won
I did the header install, and today was the fun day of doing the restrictor mod....Damn was it hard to get the valve assembly off the long metal tube....Anyhow after fighting that I checked each spark plug about a 1000 times and they are all good to go, and reattached all the emissions stuff....
Started the car, quiet for about 5 secs then bam tick tick tick tick tick etc etc etc.....
So I now know its not the spark plugs, not the AIR setup, it must be ANOTHER header leak in there.
I came to this cnclusion because.
1) the ticking sounds definetly definetly comes from the passenger side
2) When the car is in neautral (400* rpms)the ticking noise almost stops and tocks maybe every 3 secs, when the car is in D or R (500*rpms) it goes back to ticking every second
Anyone else got an idea? Or do you agree with me?
And its not the normal tick you get from headers, this is pretty damn loud, though it did seem to quiet down a tad after the restrictor mod
WSJ-I used the GM header gasket...Could that be the reason for the ticking if I put it backwards, I could have done that by being careless. I think it might be a bad weld though. I already had 1 on the other side.
If it were a fuel injector, wouldn't it of been noticable prior to the headers? Plus it is pretty constant, it just happens to "slow down" while the car is at 4000 rpms, above that it ticks constantly, and at 1500+ rpms I can't hear it cause of the catback.
Ozzy- Lifter? Why after the header install? But I do have a "wet ticking sound" like marbles in a can of oil....But thats been since day 1 and I am pretty sure its piston slap, anyhow it goes away after 15 minutes of driving.
Starting to contemplate if I should ditch the headers and go with a torque convertor and then just make my car bling bling? I guess low 13's will do
I did use the GM metal gaskets.
I am gonna punch myself in the head if thats what it is.
I can't wait for the day for this to go away. Don't know if this is relevant or not but on occasions i'll see a white smoke cloud come out of the rear through my rearview mirror, and its not even cold yet here?
I know blue means craked head or oil leaking?, black means rich/lean whichever it is.
2) When the car is in neutral (4000 rpms)the ticking noise almost stops and tocks maybe every 3 secs, when the car is in D or R (5000rpms) it goes back to ticking every second
1) I love your thread title. Bobby Fuller Four?
2) 5000 rpm in reverse? Where did you do that? Steering at those speeds in reverse is scary, right?
When I get this damn ticking noise taken care of your gonna port my TB
Thanks, I'll pass the TB info on to Bret. He's "Bauer Racing". I'm the ol' man. I get to test C5 TB mods. Tough job, but someone has to do it.
Jon
on mine...the lift is almost .600
I can hear the valves opening and shutting....
no getting rid of that...
Did you torque the header in the proper sequence and the proper torque?
If you can't hear it above a certain rpm, it's probably not a leak. A leak would get louder with the rpms. The check valve's just gonna tick pretty much the same all the time.
Dope
Soundengineer- No cam here
S2002S- Leaking head gasket, please tell me your talking about the "header" gaskets, and not something where the engine needs to get torn down.
