Swapping intakes. Difficulty?
Don't try to rush it like the guys said. Just take your time. Your not going for any speed records. Next time a buddy wants to do the mod you'll be the expert. That's a really good tip using clothes pins to hold the bolts up.
When you take the brake booster hose off you should push from the driver side to the passenger side of the intake. I think that might be what breaks the sender when you go to pull the Intake off. Just be careful not to break the sender when you move the hose, lol. Good Luck!
Probly will notice a lil bit of a difference, nothing crazy. After a tune you might see more. If your doing the H/C swap then it will pay off for sure. Have FUN!
The second time we took the intake back off, changed the sending unit and put the intake back on was less than an hour and a half.
The first time, 2 1/2 - 3 hours..?
it says these are all i need:
tools needed: 8mm, 10mm, 15mm sockets, flathead screwdriver, pliers
we do have a couple different torque wrenches, but is the fuel line disconnect neccessary? any other tools neccessary or helpful?
