!!!Installing Pacesetter Longtube headers!!!
Old Dec 14, 2008 | 02:24 AM
ttranssam's Avatar
Originally Posted by SSmokin99
I'm done with the install, BUT right now its open headers because when I connect the y-pipe to the driver side header the pipe doesn't seem to allign with the I-pipe. What could be the problem?
beat that bitch in....dont be a girl...lol its ok to be rough
Old Dec 14, 2008 | 11:36 AM
fbodyman1026's Avatar
x2 a rubber mallet is your friend
Old Dec 14, 2008 | 01:45 PM
mrnorm_hemicide's Avatar
Originally Posted by fbodyman1026
the overall install is easy, the only hard part is taking everything off IMO
+1 on that! I've been at it for 12 hrs now and I've got hung up on seperating the cat from the manifold on the driver side! Only 2 bolts broke!!! I'm right about to cut the manifold right above the flange.
Old Dec 14, 2008 | 02:13 PM
SSmokin99's Avatar
I'm glad no bolts broke during my install. I think I'm going to sell this Pacesetter ORY. What Y-pipe would you recommend me?
Old Dec 14, 2008 | 02:39 PM
The best route would be custom because no aftermarkey y setup is going to fit perfect. But if your looking for off the shelf I think tsp ory would be your best bet. Make sure you pick up some poly motor mounts if you haven't, you will thank me.
Old Dec 14, 2008 | 05:07 PM
C_B64's Avatar
tsp y-pipe if you are gonna get an off the shelf deal...
Old Dec 26, 2008 | 06:08 PM
crossroads's Avatar
what did you end up doin for your ORY? did the pacesetter fit? I ask because im gathering parts for a LT install....all I have left to order is a ORY and 02 extensions
Old Dec 26, 2008 | 11:21 PM
Vicinity's Avatar
Where did you buy yours? I've been checking sponsors and can't find **** for motor mounts...
Old Dec 27, 2008 | 06:52 AM
crossroads's Avatar
^ got mine from spohn
Old Dec 27, 2008 | 07:58 AM
LowBird's Avatar
I got my prothanes from the local napa.
Old Dec 27, 2008 | 12:17 PM
01ssreda4's Avatar
got mine from summit through ebay. OP any update?
Old Dec 27, 2008 | 06:16 PM
  #32
ruthusk8r's Avatar
some ratchet wrenches (10 mm) in particular, it will save you an hour at least, well it did for me
Old Dec 27, 2008 | 06:27 PM
  #33
firehawk#682's Avatar
i got mine motor mounts from the ws6 store
Old Dec 27, 2008 | 06:32 PM
  #34
DVS99TRANS's Avatar
Me x 2, suprised no one said anything about the vette o2 sensors. Part # 13111 if I recall. They are long enough not to use extensions and are cheaper than the stock ones for the fbody. Have them on my 99 with no problems
