Short belt mod
Old Jan 29, 2009 | 04:36 PM
jcoker's Avatar
My belt contacts the lower alt. bolt.
Old Jan 29, 2009 | 04:47 PM
nemss1's Avatar
ive heard of people having this problem and leave the lower alt bolt out or trim the head of the bolt
Old Jan 29, 2009 | 05:06 PM
the_merv's Avatar
^^I've seen that done.
Old Jan 29, 2009 | 05:51 PM
nemss1's Avatar
u using the stock crank pulley?
Old Jan 29, 2009 | 06:16 PM
jcoker's Avatar
Its an underdrive, I may grind the face of the bracket a little so I dont have to cut the bolt down so much.
Old Jan 29, 2009 | 08:50 PM
nemss1's Avatar
ya underdrive pulleys can cause that prob. ya thats what id do, find what is making contact with the belt and grind'r off
Old Jan 29, 2009 | 09:31 PM
chrs1313's Avatar
i removed the bolt...just to post this again it absolutely gained nothing in back to back runs...
Old Jan 29, 2009 | 10:05 PM
nemss1's Avatar
very true chris, no gains. i removed mine because i do remove just about everything i dont need for the car to run down the track
Old Jan 29, 2009 | 11:04 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I had to trim the bolt as well
Old Jan 30, 2009 | 03:39 PM
jcoker's Avatar
I'm just trying to get the weight down and I don't drive the car on the street very often. (looking for that 9 second motor pass)
Old Aug 16, 2009 | 03:17 PM
Intercooler2's Avatar
I know it has been a while for this thread. I have a 25% underdrive now and was pondering the short belt bypass so dug this up to find the part number. In reading here I wonder if anyone had a gain. Seems a guy I saw at the track one time said yes. Instead of spending the $18.00 I was thinking just yank the A/C belt.... zero $$$ to do and see. Thoughts on this?
Old Aug 18, 2009 | 08:42 AM
  #32
Not turning the A/C and bypassing the powersteering has to help just a little right? Might not be but 5 HP but still
Old Sep 9, 2009 | 01:07 AM
  #33
Ls1Rook's Avatar
Did anyone else try this
Old Sep 9, 2009 | 01:33 AM
  #34
LS1nut377's Avatar
im thinking about doing this in a couple of weeks for track day. but im not sure yet. a buddie of mine did the short belt mod on a dyno with heads and cam and pulled 10rwhp
from it on a dyno.so i dont know. might be worth it for track day
Old Sep 9, 2009 | 07:50 PM
  #35
Ls1Rook's Avatar
Do it let us know, i might try it too
Old Oct 24, 2009 | 06:53 PM
  #36
Gray86hatch's Avatar
Has anyone found a ribbed idler pulley to go on the alt bracket?
I have my advance auto girl working on it for me monday.
For the belt to bolt issue what about a 5 rib belt.
I have this on my ford motor with no issues
Tim
Old Feb 11, 2010 | 12:17 PM
  #37
LS88FoxBody's Avatar
I have a 5.3 I'm putting in a fox body. Looking to go with a manual Rack. Currently Have a Truck water Pump ,and all other normal accesories. Can I get away with just going with the F body alternator bracket or do I need to change other stuff?
Old Feb 11, 2010 | 01:09 PM
  #38
I know that the balancer needs to match the alt braket.
Not sure on the WP.
I am Just modded the bracket the other night for the belt to bolt clearance. As soon as I get the crank in the block I will have it mocked up to verify all the fitment.
Tim
Old Feb 11, 2010 | 01:25 PM
  #39
01ssreda4's Avatar
If its not even 5 hp then why bother. Why not leave it alone and just enjoy racing your car? Just a thought.
Old Feb 11, 2010 | 01:32 PM
  #40
Yea that was an old post. I just took off the A/C belt and left it as-is. Not worth the trouble!
