engine vibration
Old Dec 30, 2008 | 03:52 AM
Engine_HP's Avatar
Originally Posted by 99puterss
thanks for the input guys. Heres where i am at so far
replaced: balancer
Checked:
did a compression check all around 150 one was 148
changed plugs and shot each exhaust tube with a heat gun all around 160's
took my friends fuel rail of his car with 34k miles and used hsi injectors all were good
changed oil and cut open oil filter no metal shavings
car vibrates still without transmission in the car. Only thing i know left is change flywheels and see what happens. This ordeal just happened out of the blue the clutch that was in it was in the car for 7k miles and has no signs on the flywheel or pressure plate of hard spots. this is a long shot but could it be possible the computer is messed up and when ur at higher rpms above 1000k where it vibrates maybe the spark table in the computer is off? Im just throwing that out there im really clueless to whats going on it just doesnt make since the vibration is from something rotating though because its intermitant. A gm certified tech is coming to my house tommrow to see if he can figure it out so if anyone has any ideas or has been through this ordeal before please post some info.thanks
IMO no way it could be the pcm
Old Jan 1, 2009 | 02:54 AM
Engine_HP's Avatar
hey what happend with the GM tech that came to ur house on wed ?
Old Jan 1, 2009 | 10:27 AM
ls1perfcar?'s Avatar
hope you figure it out bump for you
Old Jan 1, 2009 | 10:28 AM
99puterss's Avatar
he said its the flywheel. he wants me to change with the new stuff and see what it does.
Old Jan 1, 2009 | 07:46 PM
99puterss's Avatar
new clutch and flywheel in still vibrates.
Old Jan 2, 2009 | 01:51 AM
Joshiedoom's Avatar
You have to have internal problems.
Old Jan 2, 2009 | 07:57 AM
Engine_HP's Avatar
+1.
start with ur UD pully
Old Jan 2, 2009 | 06:19 PM
MeangreenHD's Avatar
Originally Posted by Engine_HP
+1.
he already stated he changed his balancer which is his pulley.
my bet is on a bent push rod or collapsed lifter
 Michael S. Palmer
Old Jan 2, 2009 | 07:37 PM
Engine_HP's Avatar
might aswell be but it will show loud ticking (knocking) sound.
Old Jan 4, 2009 | 05:31 AM
Engine_HP's Avatar
bump for how did it go ?
Old Jan 6, 2009 | 12:07 AM
99puterss's Avatar
well so far im stumped. the motor doesnt tick at all so maybe it is a bent pushrod. has 45-60 psi at idle depending on temp outside. I dont know what to think the motor mounts are poly urethane so im almost certain thats not them. the vibration is so bad the steering wheel shakes. would a bent pushrod cause all that vibration though?
Old Jan 6, 2009 | 12:08 AM
  #32
99puterss's Avatar
+1.
the pulley was replaced with a stock gm replacement so i dont think that could be it. its something internal tho for sure ive narrowed it down that far
Old Jan 6, 2009 | 12:13 AM
  #33
99puterss's Avatar
here is what ive replaced so far just to keep ppl up to date
Replaced
New Harmonic Balancer
New water pump
New tensioner
New ps pump
New fuel filter
New flywheel and clutch
New plugs and wires
Things ive checked
Compression which all were within 5 of eachother
Motor mounts the throughbolt is tight as hell
Swapped fuel injectors with a friends car
Old Jan 6, 2009 | 02:40 AM
  #34
Engine_HP's Avatar
check out ur push rods.
i really dont think anythings wrong with them but give it a try should be a easy job.
Old Jan 6, 2009 | 04:51 PM
  #35
99puterss's Avatar
i dont think it would be a pushrod considering the motor has no ticking no noise at all basically sounds like it runs fine at idle if it was one of them it would do it all the time.
ive narrowed it down to 3 things
motor mounts which i highly doubt cuz there poly urethane
cranks messed up
ecm like the spark tables messed up
Old Jan 7, 2009 | 12:24 PM
  #36
99puterss's Avatar
Maybe a electronic issue? Could something with the PCM throw the motor off causeing the vibration
Old Jan 7, 2009 | 04:07 PM
  #37
bjamick's Avatar
Man it sounds like you've replaced everything that it could possibly be. Only thing left really is to remove the bottom end and take it and have it balanced lol.
Old Jan 7, 2009 | 04:08 PM
  #38
SladeX's Avatar
If the tune was really off you'd get knock or at the least detect it in the plugs.
Old Jan 7, 2009 | 08:47 PM
  #39
99puterss's Avatar
well i had a extra set of pushrods so i went ahead and changed them the heads were pretty clean it amazed me. still vibrates though. i was looking at my harmonic balancer a minute ago the one i replaced already underneath the car and it looks a lil wobbley from the top it looks good to go but from below it doesnt look so hot. if u look at the back of the pulley with the car on and watch the crankshaft u can see it running out. i never looked at the old one so iono if its gonna have some wobble. i tightened the hell out of the balancer too torqued it down
Crankshaft Balancer Bolt (Installation Pass-to Ensure the Balancer is Completely Installed) 240 lb ft
Crankshaft Balancer Bolt (First Pass-Install a NEW Bolt After the Installation Pass and Tighten as Described in the First and Final Passes) 37 lb ft
Crankshaft Balancer Bolt (Final Pass) 140 degrees
Old Jan 7, 2009 | 09:15 PM
  #40
Engine_HP's Avatar
ive been there be4, vibration is the hardest thing to track.
