engine vibration
Old Jan 7, 2009 | 10:54 PM
  #41
blubox's Avatar
Forgive me in advance for replying without reading the whole thread.
When you put any type of poly urithane mounts your usually gonna have more vibration. They are hard, do not give like rubber.
Just food for thought..
Old Jan 8, 2009 | 11:35 AM
  #42
Joshiedoom's Avatar
Change out the motor mounts with someone who has stock ones?
Old Jan 8, 2009 | 12:15 PM
  #43
99puterss's Avatar
Nah it's not the mounts I'm more focused on the wobbling crank pulley it's brand new from gm. I'm gonna take it off and start the car and see if the crank wobbles.
Old Jan 8, 2009 | 05:04 PM
  #44
Engine_HP's Avatar
hey btw a nice way to know if it was the engine mounts or not. u can jack the engine from under (lift it) and start the engine and see it its still vibrats
Old Jan 8, 2009 | 07:55 PM
  #45
99puterss's Avatar
ah i think somethings fucked in the motor the balancer pulley wobbles and its a new pulley
Old Jan 8, 2009 | 08:37 PM
  #46
Engine_HP's Avatar
have u tried jacking the engine and staring it ?
Old Jan 8, 2009 | 10:03 PM
  #47
99puterss's Avatar
naw i havent jacked the motor up but i tried to pry up on the motor mounts and they barley moved
Old Jan 9, 2009 | 12:05 PM
  #48
blubox's Avatar
I never said they were broken..I said they were good. If you just put poly mounts you will have more vibration. Maybe your pulley is wobbly..Then the mounts are making it vibrate even more. Did you pull the pulley and start it yet? That will tell you right away if it's the pulley.
Was the problem there before you put the new pulley on? If not then wehn did the problem start?
 Michael S. Palmer
Old Jan 9, 2009 | 09:35 PM
  #49
Low02's Avatar
I'm having the same problem, I hope you figure it out soon so i will know where to look. Good Luck!
Old Jan 10, 2009 | 08:30 PM
  #50
Low02's Avatar
Any news??
Old Jan 11, 2009 | 02:09 PM
  #51
99puterss's Avatar
i got the car scanned o2s were at 850 870 no misfires and i had one previous code on there a generator code p1637c which says its a generator t terminal circuit so im guessin its the alt code but my alt charges so thats y the code was a previous one. anyways so that rules out the computer now im back to either motors fucked or i didnt put the clutch in right i go down the road and once u get above 2k rpms i have very little vibration issues u cant even tell its there but anyhting from 1k to 2k its there.
Old Jan 11, 2009 | 02:13 PM
  #52
blubox's Avatar
So the problem started right when you put the clutch in or what? Seems like WAAAY to much hunting around just to still have the problem, I would have to ride in it to get a feel for it but some vibration it normal. Alot is obviously not.
Old Jan 11, 2009 | 02:20 PM
  #53
99puterss's Avatar
the problem started before i touched anything on the car one day it started doing it. motor loaded not loaded clutch in clutch out.
Old Jan 11, 2009 | 02:33 PM
  #54
hawk18's Avatar
Default shake
watch under the hood and see if the balancer shakes
Old Jan 11, 2009 | 02:46 PM
  #55
99puterss's Avatar
it shakes a little at idle but ive changed it with a new gm one. once u put a load on it it smoothes out some
Old Jan 15, 2009 | 04:26 PM
  #56
99puterss's Avatar
ok lets start over.
when the cars cold and i get in it in the mornings it doesnt seem as bad.
at 70 mph its vibrates terribly
i have a 6 speed so at idle in neutral it vibrates
i have poly mounts but how likley is it that one is ript? they look fine and when i pry on them with the motor running it seems fine. but they are poly and dont give that much so i cant rule that out can i?
Old Jan 15, 2009 | 06:03 PM
  #57
BRD-PREY's Avatar
I have exactly the same problem and noticed mine after a LS7 clutch install. I pulled it out and had the Flywheel and Pressure plate balance to .5 gms. I swapped the balancer. I'm stuck too. I was even looking for a decent prices on a EVA vibration analyzer on Ebay. Mine kicks in at 1300 to 1400 rpms and has a 4 count beat to it. I was wondering if I noticed at the clutch change but it was there already? I also have been kicking around whether the vibration could caused by the exhaust. I have a GMMG resonator exhaust. I thought maybe I was getting a pulsing vibration from the exhaust that was at a resonant frequency of the car. This could harmonically vibrate the vehicle??? I know I'm stretching on that one.
Ed
Old Jan 15, 2009 | 06:10 PM
  #58
99puterss's Avatar
ive heard of ppl with cats having vibration issues from a clogged cat but iono mine sounds like the vibs from the exhaust but iono man how long have u ran it like that?
Old Jan 16, 2009 | 08:05 AM
  #59
BRD-PREY's Avatar
Its been since Thanksgiving. I really good Chevreolet Tech said the LS was know for that off idle vib. He even told me the rpm before I mentioned it. Said some are worse that others.
Ed
Old Jan 16, 2009 | 09:56 AM
  #60
99puterss's Avatar
Ya but how does it just happen? If he's good why hasn't he told you what the proble
Is?
