SLP 85mm MAF
Old Sep 29, 2003 | 10:03 AM
DEEZ98Z's Avatar
Default SLP 85mm MAF
Who is running this?? Is it worth the money? Or should I just pay the extra $100 dollars for the granetti?
Old Sep 29, 2003 | 11:17 AM
OctaneZ28's Avatar
Default Re: SLP 85mm MAF
I have it on my car.
I can't say whether it helped or not, but I figure the larger MAF versus the stocker is worth more airflow.
Come time for a dyno tune, I'll probably go back to the stocker.
MAF is a hit-or-miss thing. Some people have the best luck with the stocker, while others have good luck with aftermarket ones.
I'd say give it a shot, and if it works for ya, then cool. If it makes the car run crappy, then just go back to the stocker.
Old Sep 29, 2003 | 11:39 AM
DEEZ98Z's Avatar
Thanks for the feedback....
TTT
Old Sep 29, 2003 | 12:20 PM
Sunset01SS's Avatar
I don't think it did squat. May have even hurt performance. I'm gonna put the stocker back on & then I'll tell for sure.
Old Sep 29, 2003 | 12:25 PM
Smoke_Ford's Avatar
Mine worked great, car ran fine.
Old Sep 29, 2003 | 01:44 PM
Nasty N8's Avatar
I use them on many cars they work great. I tune with them on most cars no probs.
Nate
Old Sep 29, 2003 | 04:26 PM
DEEZ98Z's Avatar
I should have known that it would go both ways with a MAF... they are a touchy topic
Old Sep 29, 2003 | 04:44 PM
B-MAN's Avatar
SLP MAF sensor is the way to go. best bang for the buck
Old Sep 29, 2003 | 08:16 PM
WS62GO's Avatar
Mine looks great mounted on the wall of my garage. It was making my tranny shift weird.
Went back to stock-car feels much better.
Old Sep 29, 2003 | 09:53 PM
soundengineer's Avatar
the stock MAF is good up to about 500-550 hp
If your not close...you dont need it...spend your money elsewhere...port and polish Throttlebody,do the bump stop mod....use it towards an LS6 intake or something that will make a difference.....
I just did the intake...I'm at 400 now....without heads....
Old Sep 30, 2003 | 12:12 AM
DEEZ98Z's Avatar
Thanks... that is the answer that I needed I will put that twds my LCA's
