MAF delete bellows
Old Dec 28, 2008 | 12:36 PM
Mike454SS's Avatar
Default MAF delete bellows
I'm running an HP Tuners 1-bar enhanced OS without my MAF sensor. Does anyone know of a bellows or coupler (even something thats OEM on another car?) that will allow me to connect my lid (SLP if it matters) direct to my throttle body? I know I need 4" diameter on both ends, but everything generic I can find is a 45 degree bend and isn't long enough. I guess I can see what I find for rubber instead of silicone at Home Depot...but I don't expect to have much luck there either.
Only other option would be a piece of straight pipe where the MAF currently is, but I think that'd look kinda cheesy compared to a single bellows from the lid to the TB.
Old Dec 29, 2008 | 09:58 PM
greatskiiiier's Avatar
piece of straight pipe from lid to TB
Old Dec 29, 2008 | 10:05 PM
Super Speed's Avatar
I'm in the same predicament, I'm currently using a piece of PVC pipe but it looks tacky, hopefully someone can chime in!
Old Dec 30, 2008 | 01:57 AM
Emoney97ss's Avatar
i found a big 4 inch polish piece by sceptre or something like that, its some import place that had it...
Old Jan 1, 2009 | 12:48 PM
Could you pm with the link?!?! Thanks!
Old Jan 5, 2009 | 12:18 PM
EW1's Avatar
EW1
you could get a 4 inch aluminum pipe and cut it to fit from spectre and they also have silicone couplers also. I know pep boys, summit, and jegs sells them. I believe they are cheaper at JEGS.
Old Jan 5, 2009 | 12:52 PM
ChrisS@sdpc's Avatar
A little pricey, but you could check here.
Old Jan 5, 2009 | 01:43 PM
Mike454SS's Avatar
Pricey is alright if it works...they don't have 22 degree bends in anything larger than 3" though, and I think a 45 degree bend is too extreme.
Old Jan 5, 2009 | 02:47 PM
Blown383LS1's Avatar
How long does it have to be?
Old Jan 5, 2009 | 04:36 PM
I think its around 4 inches!
Old Jan 5, 2009 | 04:37 PM
http://www.jegs.com/i/Spectre/865/9719/10002/-1 this looks like it might work!
Old Jan 6, 2009 | 10:39 AM
Magic Man's Avatar
I got mine from http://www.intakehoses.com. I got a piece 6" of the 4"id silicone hose and a 4" piece of the 4"od aluminum tubing and the with some lube and a little force inserted the tubing into the hose.I did have to cut about a 1/4 to 3/8 off the tubing and work a little on the inside of the hose to get it to fit over the fast toys 85 mm lid which has an od of a little over 4"(around 104mm).I also had to cut ot a small protion of the radiator suport to get it all to fit but is pretty much a straight shot to the tb.
Old Jan 12, 2009 | 10:56 AM
HavATampa's Avatar
22 degree 4" rubber bend but still not long enough to do your project in one piece. You could fill the gap with a 4" piece of aluminum tubing and small a straight 4" silicone coupler. This piece isn't cheap though.
http://store.airflo.com/22hl4.html
Old Jan 12, 2009 | 01:20 PM
JonCR96Z's Avatar
Here's what I'm using. I just borrowed it from someone so I don't really know the price, but it's a piece of 4" exhaust pipe a 4" coupler and a 4" bellow.
Old Jan 12, 2009 | 01:59 PM
kyles2000z's Avatar
intakehoses.com
they have a 4x6 inch silicone hose that works perfect, i just got mine over christmas. great customer service as well. it was like $28 shipped, but well worth it.
Old Jan 12, 2009 | 02:02 PM
kyles2000z's Avatar
Old Jan 12, 2009 | 02:27 PM
00Antivenom's Avatar
This may be a stupid question...in fact it is. Why do people delete their MAF?
Old Jan 12, 2009 | 03:29 PM
JonCR96Z's Avatar
Because we can.
Old Jan 12, 2009 | 03:33 PM
Originally Posted by JonCR96Z
Because we can.
Benefits? Problems? I thought it was kind of a necessary part...
Old Jan 12, 2009 | 03:38 PM
JonCR96Z's Avatar
With a proper SD tune you'll not only make the same potential power, but you'll have better throttle response. Plus you're losing some weight by removing the MAF and a small intake restriction.
It is a must do on boosted applications.
