Should i change my timing chain?
Old Dec 28, 2008 | 06:13 PM
scidav87's Avatar
Default Should i change my timing chain?
2000 LS-1 car has 101K put in an MS3 cam at 99K, timing chain had the normal 100K loosness you would expect, i didn't change the timing chain (didn't have time or a chain). Do you think it would be worth it to tear the motor back down just to replace the chain with an LS-2 unit? How often do stock ones actually fail under 200K? Just courious, its alot of work lowering the oil pan and everthing else having no lift just to replace a timing chain that still works. THANKS for the input.
Old Dec 28, 2008 | 06:32 PM
01ssreda4's Avatar
i would do it.
Old Dec 28, 2008 | 06:43 PM
'02 WS6's Avatar
x2. I would too. If you didn't upgrade to a ported LS6 oil pump, that would be another beneficial excuse as well.
Old Dec 28, 2008 | 06:51 PM
scidav87's Avatar
Is it pretty easy to do the install, drop the pan, etc without using a lift.
Old Dec 28, 2008 | 11:10 PM
cyacops's Avatar
i tore mine apart just 2 do the dual timing chain and oil pump.. u can also just put an ls2 chain but i would do a ported pump while yur in there
