TB porting?
Old Jan 3, 2009 | 02:04 PM
  #41
shawn_c992001's Avatar
To finish mine I used 0000 grit steel wool, and then some Flitz metal polish.
Old Jan 3, 2009 | 02:08 PM
  #42
shannon french's Avatar
you can also use teh teh lq4 tb since it is a 80mm from teh factory. and its cableactuated. just learne dthis not to long ago. wich i woulda known when i was doing my buid
Old Jan 3, 2009 | 04:46 PM
  #43
Bo White's Avatar
Stick with the big names that are proven if you dont wanna tackle it yourself and you cant go wrong.
Old Jan 3, 2009 | 07:13 PM
  #44
lunatik's Avatar
Originally Posted by Chubbz155
Thanks for all the input fellas!! So you guys think that it is really worth the $?
yes, definitly. If you can afford the small down time then send it off. I did my over a weekend. took out the ridge and did the half shaft mod. Havent done the bump stop yet. I dont have a surgeons hand and scratched he mating surface of the blade/tb. It wasnt enough to hurt the idle but finding and buffing out the catch in the blades opening and closing (yup-stuck the throttle some) was time consuming. If you pride your own work then give it shot, take your time. If that is of no concern then send it off. $65 is a great value for the work and piece of mind. Good luck.
Old Jan 4, 2009 | 12:38 AM
  #45
Chubbz155's Avatar
Originally Posted by 9000th01ss
It wasn't my intention to bash people, I was trying to motivate people. I screwed that up big time.
I used an air powered die grinder with a carbide burr. I forgot the name of it, the one shaped like a christmas tree but more rounded. About 1/2" diameter.
I looked for and could not find a how to for it.
I do know the most important thing is to not touch the area where the blade sits when it's closed, I used a paint marker to trace around it after cleaning and before disassembly.
It's obvious when you look at it what to do.
As far as finish goes I left it rough on purpose, I read a thread here about the CNC'd stock TB's and why they are left with a rough finish.
I did sand it a little bit to match the look of the average ported TB pics you find here.
Sorry it took so long to answer this, but I went to WI to pick up some old 73' Renault 12L with 2 buddies!! One of my buddies new projects!
I appreciate the input! I was defiantly thinking about a angled bit. I am going to order one thru my cutting tool supplier at work on Monday. I will be working on it next weekend! Keep an eye on this for pictures! Thanks again guys!
Old Jan 4, 2009 | 12:42 AM
  #46
Chubbz155's Avatar
Originally Posted by regency
here is the very first one i ported!! I have done about 20 so far and have a great design figured out now that ive used on about the last 12 of them!!!!
That TB looks great!!! Nice job!!
I defiantly can afford the own time since it is in the barn (stored for the winter).
Last edited by Chubbz155; Jan 4, 2009 at 12:43 AM. Reason: Got rid of pictures from quote.
Old Feb 14, 2009 | 10:52 AM
  #47
Chubbz155's Avatar
I decided to order my TB from the Powder Pro. I just received it yesterday and it looks great and operates amazing!!! I highly recommend him!! A+ work!
