tfs 235 with ls7 head gasket?
Old Jan 7, 2009 | 01:19 PM
TJ's Avatar
TJ
Originally Posted by Brian Tooley
I was faced with the same delimma on my 6.0L iron block, I bought the LS7 gaskets and found they wouldn't work. I had to bite the bullet and buy Cometic.
TFS also sells the gaskets you need.
the only issue with a cometic for me is leaking.
Old Jan 7, 2009 | 03:01 PM
SIC LSX's Avatar
well Brian tooley is spraying a 250 shot and he didn't say anything about him having problems I have used them on a few cars with no problems
Old Jan 7, 2009 | 10:09 PM
TJ's Avatar
TJ
the surface must be 100% perfection for them to seal. one lil spot, and she is gonna leak.
Old Jan 7, 2009 | 10:14 PM
SIC LSX's Avatar
on one of the car we used the spray sealer on the gasket
Old Jan 8, 2009 | 07:39 PM
SSwanner's Avatar
Originally Posted by TJ
the gasket is only 4.03x. the head i believe is 4.100.
not sure what effect this has on performance or longevity.
... my bore is 4.030" and the gasket is a few thousands more...
**i would NEVER put a steel head gasket of any sort on any motor dry. i use copper head gasket spray or mopar head gasket spray.
Old Jan 8, 2009 | 09:18 PM
TJ's Avatar
TJ
i measured an l92 gasket myself today. 9 out of the 10 bores were 4.10xx and one was 4.90xx
the head is going on a 4.030 bore block, so i shouldnt have any interference with gasket, IMO.
