Friend just installed ls6 intake throwing code
Old Jan 9, 2009 | 06:15 PM
SIC LSX's Avatar
Default Friend just installed ls6 intake throwing code
The code is PO17401 system to lean. Intake leak is what im guessing???
Old Jan 9, 2009 | 06:45 PM
twitchtwice's Avatar
well it would make a little sense if its saying lean because he is getting a little more air flow maybe?
maybe he just needs to drive it a bit and the computer will learn the ls6 intake.
Old Jan 9, 2009 | 06:48 PM
XtraCajunSS's Avatar
Yes. You are correct. Vaccuum leak is the culprit. Make sure the gaskets are all good and that the intake is torqued properly. Also, make sure all vaccuum and PCV hoses are connected and routed properly.
Shane
Old Jan 9, 2009 | 07:29 PM
booger78z28's Avatar
i had actually had some paint on the gaskets and forgot to change them out, would this also be a culprit?
thanks in advance, thanks for posting dan.
Old Jan 9, 2009 | 07:57 PM
TORCHD 02 TA's Avatar
I think you have an intake leak b/c of the gaskets? Did you buy new ones? Or are you using the stock crushed ones?
Old Jan 9, 2009 | 08:07 PM
SIC LSX's Avatar
When i 1st got to his house to install the intake i saw the gaskets and they were flat and had pant on them I was going to pull them out and reuse the ones from ls6 intake. Well long story short i forgot about it until it was to late. So im thingking its the gaskits
Old Jan 9, 2009 | 08:35 PM
bczee's Avatar
Try using some carb cleaner spray and spray some around the area of the seal, one area at a time, and if there is a short change in engine RPM's, then you've got a vacuum leak at the area you just sprayed.
Check all of the hose, even at the power brake booster. Did you check your MAP sensor, Throttle body, etc ?
Good luck
Old Jan 9, 2009 | 09:11 PM
SIC LSX's Avatar
yeah i told him to do all that when he had a chance
Old Jan 10, 2009 | 06:24 PM
SIC LSX's Avatar
took it apart and yup some of the gaskets were bad so he got new ones
Old Jan 10, 2009 | 07:14 PM
Mike454SS's Avatar
That makes sense...air was getting in without the MAF sensor seeing it, and the O2's were forcing a large correction hence the code. If the car were speed density it wouldn't have thrown the code...which would make it harder to know there's a vacuum leak.
Old Jan 10, 2009 | 09:36 PM
jrob56's Avatar
I have yet to start my car since the my swap i need to send out my tb for porting still, but i reused the gaskets on it. came off a 30k mile z06 gaskets looked pretty good, how many people reuse the gaskets?
Old Jan 10, 2009 | 09:53 PM
97blackz28's Avatar
I reused the stock LS6 gaskets when I swapped heads/cam and have had no problems. Mine looked pretty good so I saw no reason for new ones.
Old Jan 11, 2009 | 06:02 AM
when i took it back off i noticed 2 gaskets were completly missing.....didnt look at them before the install,........leason well learned
Old Jan 11, 2009 | 09:37 AM
OK got the 2nd intake install over with now..
let it warm up, took it out and drove a little bit , no codes but still runs a little rough.... would this be the computer trying to relearn everything from unplugging the battery, and if so how long does it usually take ?
THANKS for all your replys
Old Jan 11, 2009 | 12:56 PM
jrob56's Avatar
That sucks sounds like something I would do...
I would guess so, mine ran a little rough every time Ive disconnected the battery(lid install, header install, and Im expecting the same when I finish the intake install). If it doesnt smooth out after a few days then Id worry...
Old Jan 12, 2009 | 01:02 PM
LilJayV10's Avatar
The gaskets didn't drop into the head did it?
Old Jan 12, 2009 | 01:19 PM
1 Bad Ass Formula's Avatar
My suggestion to anyone installing a used LS6 intake is to install new gaskets. Once the intake has been put onto a car the gaskets conform to the torque specs and the heads of that specific car.
Old Jan 12, 2009 | 03:38 PM
no, i hope not, thought i would have seen it or had problems with it buy no
the older ones on there were hard to pull out anyways....
