Quick question
Old Jan 10, 2009 | 05:18 PM
Eighty7camarokid's Avatar
Default Quick question
Im in the process of putting some hooker LTs on my 98 Z. Im having trouble getting the LTS up into the engine bay, theres just no room to maneuver them. My question is, when you put your LTs on, how high did you jack up you car? My bumper is about 3 feet off the ground right now and it still doesnt seem to be enough
Old Jan 10, 2009 | 05:22 PM
jsteele90's Avatar
did you remove your steering shaft on the drivers side? i didnt really have to jack my car up that high to install mine.
Old Jan 10, 2009 | 05:33 PM
69_YENKO's Avatar
I had to jack mine up pretty high to get the pacesetters to go in. I had a crappy small floor jack 19"max with a couple 2X4(yeah i know, i did have jack stands in use also) on top to make it work. so it was probably around 24" up at the center of the K member and close to 3' at the bumber.
I didn't remove the steering shaft either
Old Jan 10, 2009 | 05:45 PM
No, i havent removed the shaft. I have my car jacks up as far as they will go and its just not enough.
Old Jan 10, 2009 | 05:54 PM
waterbug1999's Avatar
Get it up higher..... if the collectors are hitting the ground before you can get them up in there, not high enough.
I had some older Pacesetters 5 years ago and I had to lift the block up a little.
Old Jan 10, 2009 | 06:02 PM
69_YENKO's Avatar
yep, you just need to go higher, barrow a taller jack of something, its got to go.
I would never suggest someone else use blocks but it worked for me
EDIT: come to think about it I had the rear end up in the air on jack stands also that may have helped me some??
Old Jan 10, 2009 | 07:25 PM
HMERacing's Avatar
You all are some crazy *************!
Dont you have a buddy with a lift, or someone that can let you use one? I installed mine at a Ford garage.
Old Jan 10, 2009 | 09:27 PM
69_YENKO's Avatar
its too late for that now, hes already got them off
 Michael S. Palmer
Old Jan 11, 2009 | 11:58 AM
OK, so Ive notched the K member, hammered the body, and its still not wanting to go in on the drivers side. Its wedging between the steering shaft (which I cant really get off), a little block on the engine block, and the firewall.
Old Jan 11, 2009 | 12:22 PM
Your talking about the square looking nobby looking thing on the block correct?
You can shave it down to get the right clearance or loosen up the big motor mount bolt and push the motor up and squeeze the header in.. I ended up doing both.
Old Jan 11, 2009 | 12:28 PM
Yes, thats exactly what Im talking about.
Old Jan 11, 2009 | 12:54 PM
i found this...seems like these headers are a pain..lol
https://ls1tech.com/forums/generatio...r-headers.html
Old Jan 11, 2009 | 12:58 PM
Should be a breeze now.... Good luck.
Old Jan 11, 2009 | 01:09 PM
Ok, so I took off the steering knuckle and undid the motor mount. Still will NOT go in.
Old Jan 11, 2009 | 01:26 PM
Well, undoing the motor mount wont just do it... You have to push that side of the motor up.
Old Jan 11, 2009 | 01:36 PM
I know. We jacked the motor up so high that the power steering line came loose an spilled everywhere.
Old Jan 11, 2009 | 01:40 PM
BlueMagicSS's Avatar
Did you jack the back of the car up as well?? I had some trouble with the driver's side with Edelbrock LT's but a little banging and manuevering and they went in... it did take me a minute though.... But do make sure your back end is jacked up as well... You shouldn't have to remove the steering knuckle, motor mounts, and everything like that... do you see exactly where it's hitting at??
Old Jan 11, 2009 | 01:41 PM
Yikes.... You see how much the motor has to move to clear that stub on the block,, Mine only took a little tilt of the motor and it went in.. Are you sure you have the right headers?
Old Jan 11, 2009 | 02:07 PM
We finally got it in. had to unbolt the motor mount bracket. Along with everything else.
Old Jan 11, 2009 | 02:09 PM
Damn dude.... But, glad you got it.
My 1st time I did it alone, it took 2 days, alot of beer and curse words.
