Typhoon intake?
Old Jan 17, 2009 | 10:19 PM
twpetry's Avatar
I don't know that test was done on a h/c car, i dout results would be worth the money on a bolt-on car...
http://www.professional-products.com...ests/52060.pdf
Old Jan 18, 2009 | 12:39 AM
thunderstruck507's Avatar
sounds decent to me...would like to see some more results, just curious why no one talks much about this one
Old Jan 18, 2009 | 01:18 AM
00Antivenom's Avatar
It's an aluminum intake and gets heat-soaked under the hood. Most people here like to go with the traditional poly-carbon plastic blablabla ones.
I believe the tests were done on a H/C car. I'm gonna get this setup before I get my H/C package, but that will be two less bolt-ons I have to worry about to get the most out of my cam.
Old Jan 31, 2009 | 11:55 AM
JJD49's Avatar
Originally Posted by w3s1c0a5t
Do you got dyno graph over lays? That doesnt sound much better than an ls6 but id love to see how his curve looked.
I don't have access to his dyno sheet. maybe he can send it to me
Old Jan 31, 2009 | 12:07 PM
JJD49's Avatar
They won't give you as much Power as a FAST but for Under $500.00 including Fuel Rails and Braided lines , it is a pretty good deal.
People don't talk too much about it because it is made out of alluminum and they fear the dreaded heat soak. I have not had any issues to bitch about since the day it was installed. If you do back to back runs at the track, heat soak might be a problem. But on the street, it is no worse then a Composite intake
Old Feb 2, 2009 | 02:08 AM
jessesta's Avatar
You never took yours to a dyno? I just would like to see some real numbers. someone has to have done some sort of dyno test on it besides the manufacturer
Old Feb 3, 2009 | 01:49 PM
JJD49's Avatar
My car has been on a Dyno. The shop that does my work uses a Mustang Loaded Chassis Dyno. These Dynos read lower then a free wheeling Dyno Jet.
Numbers before intake install were 379 RWHP & 401 RWTQ
After install the numbers were 397 RWHP & 429 RWTQ.
