AC delete on 02 z28
Old Jan 14, 2009 | 07:48 PM
maskedman58's Avatar
Default AC delete on 02 z28
I want to delete my AC on my Z28. do I need a delete bracket?
Old Jan 14, 2009 | 08:56 PM
conan's Avatar
I deleted the bracket, compressor, belt, radiator, dryer can, and all the aluminum plumbing back to the fire wall. Get rid of it all less weight more room to work in the engine bay.
Old Jan 14, 2009 | 09:01 PM
zach_ws6's Avatar
doing it for weight i assume? otherwise, just take off the second belt.
Old Jan 15, 2009 | 09:52 AM
yeah Im taking it off to save weight and clean up the engine bay. I never run it anyway.
Old Jan 15, 2009 | 09:59 AM
Tainted's Avatar
yup you will need that bracket but save all your stuff just in case you decide to put it back on someday
Old Jan 15, 2009 | 10:00 AM
WS SIKZ's Avatar
unless it doesnt work or unless you have a drag car i wouldnt do it lol my compressor was blown so i said screw it but when its 100 degrees in a black car on black leather or its all fogge up you wish you left that **** it haha and take it out before if you plan on doing headers and motor mounts or cam
Old Jan 15, 2009 | 11:07 AM
the_merv's Avatar
No you won't need a Delete Bracket.. just remove it all and the Belt off of the Pulley.
Someone honestly find me a LS1 AC Delete Bracket/Pulley.
It's not like the LT1 where you have to keep the Belt going the same path. I know cause I did it.
If you want to get crazy with it you can take everything off of the Fire Wall too..
Old Jan 15, 2009 | 11:12 AM
gmmusclecarman's Avatar
how hard exactly is it to get everything off the firewall? ive been meaning to do finish it the rest of my ac removal but i havnt had much time to work on the car. I have today off but seeing as how its almost 20 below out and the car is buried in 6 inches of snow, i dont think its gonna happen soon.
Old Jan 15, 2009 | 11:16 AM
the_merv's Avatar
It's easier with the Engine out. I'm sure it could be done with it in, but it would be a pain. I did it when I was building a Motor for mine and when the car was just a roller. I used a Dremel and cut it all out.
That Panel is made out of 1/16" Aluminum, I still have the Heat.
Old Jan 15, 2009 | 11:21 AM
my engine is out so that helps. is it necessary to use a dremel on it? it looks like it just unbolts from the firewall.
Old Jan 15, 2009 | 11:23 AM
the_merv's Avatar
Part of it un-bolts, you will see that when you get in there and start taking things apart. I kept heat, so I kept the part of the Box that was on the inside. Some people remove the whole thing cause they take everything out.
I'm looking into getting a little Blower Motor and building a Heater Box for mine, it doesn't blow as hard as it used too..
lol I was going to take it off today cause I might get headers next week. I am not doing it cause its like 30 degrees here in florida lol I thought it was cold here.
Old Jan 15, 2009 | 11:27 AM
yeah theres a number of things i need to do on the car but the weather has been so shitty that i just said **** it until it warms up.
Old Feb 9, 2009 | 03:45 PM
so is there any possible way to get the box off the firewall without cutting it off?
Old Feb 9, 2009 | 03:50 PM
nemss1's Avatar
you could remove the dash and remove the entire box assembly, thats if u dont care for no heat or a/c like me. but to keep heat, your gonna have to still cut the box
Old Feb 9, 2009 | 03:57 PM
what can i use to cut it other than a dremel tool? I dont have one.
Old Feb 9, 2009 | 04:03 PM
nemss1's Avatar
could use a steak knife or an angle grinder
