misfire in cylinder 1... Desperate
got an occasional slight miss from cylinder 1 thought nothing of it really. But
then about a week ago that miss turned into a big deal giving me a flashing
ses light on the way home. so i turned it off and checked the code it didnt
tell me anything out of the ordinary besides fuel level sensor circuit. so i am
gonna hafta assume that they turned of the cylinder misfire codes. After i
checked and saw nothing that could help figure out the problem i started it
up and it was fine like there never was a problem. that continued for about a
week The problem being that at idle or part throttle it would miss in cylinder 1
but not at full throttle and only after running for a minute or so and if i turn
it off and then on again fine for a minute until something happens that
causes the miss. i checked the plug and wires there appeared to be arching
cause the plug had burn marks on it as did the wire so i replaced them and
later on the coil just trying to fix the problem. so i dont think its a spark issue
maybe leaking injector but i have no clue why it would only do it after
running for a bit. It doesnt do it every day either just when it feels like it i
drove 156 miles and no problem but then on my way to and from work it
crapped out so i dont think theres any reason for when it does it. If there is
anyone that can help i would appreciate it immensely. and sorry for the long
post
EDIT: No you're right he did replace the coil
