True Duals vs y pipe setup
and will the TSP true duals tuck up enough to not be seen very well? cause ive seen some true dual setups that looked absolutely horrible and you could easily see them. it looked like they were about 2 inches away from scraping the ground.
anyone got some pics they could post up of TSP true duals on there car?
I think the best would be as in the pic above, a custom Y 3 in 4 out, then an electronic cutout, then reduced to 3 to a rear muffer setup of your choice. Put a 3 bolt type clamp right there before or after the cutout & you can unbolt all the weight of the rear muffler, and bolt up a bullet, as in the pic.
I doubt there would be much difference between the properly setup Y & the TD. I'll let you know as I have the TD's with bullets on there right now & plan too switch to the Y when things warm up. Running 129 MPH with TD's.
I like the Patrick G setup.
single 3" - 7 square inches
single 3.5" - 9.62 sq in
dual 2.5" - 9.8 sq in
single 4" - 12.5 sq in
dual 3" - 14.1 sq in
Obviously, you add Xs, Hs, and merges from one to the other, that complicates things BUT - going from single 3" y pipe to true 2.5" duals give you theoretically about 40% more flow. It may not be super noticeable below 350whp but it is measurable below that and moreso as power increases.
Another note, NO mod we do increases power by a fixed number, it increases by % and multiplies out to HP. Even then, it's not linear - but you should get the idea.
The nice pic of the y pipe above (4 inch with flow merge) is a nice Y but damn near dumps, not a full system by most street standards. Y setups fit closer to stock, are lighter, and cheaper since there are fewer parts. Dual setups are heavier, more expensive, have more potential clearance issues, but sound better and make more power.
Short version - properly done full length duals will always outperform proper full length y pipe and cat back setups. It's hard to do apples to apples since there are SO many variables on these systems and art plays a big role but the math does not lie regarding true potential. Pick what fits your needs best, usually it's budget first for most of us.
I need a chassis mounted tq arm to be running a 408 right? or can i use a trans mounted one still. I want my suspension to be able to hold 700+rwhp.
so i guess maybe i should just stick with a y pipe....
Im also about to buy a used set of 1 7/8x2 kooks LT headers and they wont work with TSP true duals because the collector is too big.
EDIT: Here is your answer:
https://ls1tech.com/forums/generatio...nel-brace.html
Good luck!
/hijack
I guess now what im worried about is what headers and exhaust setup wont have any clearance issues?
UMI has TA setups, including relocation kits, to fit most any kind of exhaust.
http://www.umiperformance.com/produc...ategory_id=130
Kooks headers (great choice, btw)
then decide if you want the Y = catback or TSP's duals - either should fit with that TA setup.
Duals WILL be loud but if you're not going with cats anyway, the TSP duals will be cheaper than catback + Y. If you already have an aftermarket catback, you can sell it to recoup some costs.
One more thing... If your roads are as shitty in IL as they are here in MN, then you will probably want the y just for the fact that you don't have to worry about loosing your exhaust on the highway.
Have not had any trouble with cops yet... I bet you I can make more power with a y pipe than with duals. Maybe only 1 or 2hp, but I bet I can do it with a good Flowmaster merge with a 4" outlet.
This is one of mine. I bet you an X or H wil not scavenge like this. Both banks flow parrallel instead of colliding like an x.
Wow ignorance is bliss hahahaha I will take that bet I will go to the dyno with you if ya likem you bring the exact Y thing you pictured. We will do a back to back against my true 3 in duals with Dr gas X I guarentee I will not only make 15-20 more rwhp with my setup but it will sound a 1000 times better! I have already done a back to back with a nice Y-pipe with a 4 in outlet and used a custom collector in the Y-pipe.
