True Duals vs y pipe setup
https://ls1tech.com/forums/dynamomet...-500-rwhp.html
I am just doing what is known to work well. Maybe you are the one who is a bit misinformed.
As do I.
) I really like how the mufflex sounds with a flowmaster, so I think I would like the setup you're talking about with a single chamber. Maybe dump it at the back like the mufflex but add a cutout somewhere up front. If push comes to shove I could build it and ship it to you.
single 3" - 7 square inches
single 3.5" - 9.62 sq in
dual 2.5" - 9.8 sq in
single 4" - 12.5 sq in
dual 3" - 14.1 sq in
Obviously, you add Xs, Hs, and merges from one to the other, that complicates things BUT - going from single 3" y pipe to true 2.5" duals give you theoretically about 40% more flow. It may not be super noticeable below 350whp but it is measurable below that and moreso as power increases.
Another note, NO mod we do increases power by a fixed number, it increases by % and multiplies out to HP. Even then, it's not linear - but you should get the idea.
The nice pic of the y pipe above (4 inch with flow merge) is a nice Y but damn near dumps, not a full system by most street standards. Y setups fit closer to stock, are lighter, and cheaper since there are fewer parts. Dual setups are heavier, more expensive, have more potential clearance issues, but sound better and make more power.
Short version - properly done full length duals will always outperform proper full length y pipe and cat back setups. It's hard to do apples to apples since there are SO many variables on these systems and art plays a big role but the math does not lie regarding true potential. Pick what fits your needs best, usually it's budget first for most of us.
Flow isnt really the issue. Its proper scavenging. A Y pipe is the best inductor hence when properly setup makes an excellent system. And when is dumps not a street system i run it... and so do... well hundreds of other cars...
Most people dont run duals out the back... hence they are lighter than a catback Y setup. Their not more expensive IF you are going to run a catback. They sound better than Crappy Y's because of the rasp associated with a bad merge. The Y pipe pictured does NOT suffer from that. My setup IS the one pictured and it sounds just like dual bullets.. Except mines a little deeper.
So.... Uhhh... What did you answer?
