how to hook up an A F RATIO gauge on a camaro
i hope your using a wide band and not one of the cheap ones that use your factory O2 sensor. because if thats the case your wasting your time on a light show that dosnt do anything for you.
what do you have, a make/model would be nice, ie: lm-1 lc-1 aem etc...
for my LM-1 install I had a new O2 sensor bung welded into the drivers side pipe of my true duals 4-6" after the collector.
my WB is a universal type meant to be easily used in different vehicles so all i had to do was:
1.)install the sensor in the bung
2.)plug one end of the harness into the sensor
3.)plug the other end of that harness into the display
4.)take the 12+v adapter and insert it in the display
5.) plug the other end into the cigarette adapter in the dash
6.)turn it on, i was done.
