Valve Float
Tell us everything about your valve train so far. Plus specs for your cam.
Thanks for the info so far!
Shane
Shane
Shane
Im sure youll get a good set of springs and set them up as well as you can. Let us know how it goes.
I will deffinately be posting up my dyno numbers when shes done
How do you know? Do you know the moment of inertia of these rockers?
Agree, but sometimes you have to do unconventional things to solve a problem.
.610/.612
They reccomend the Patriot gold duel springs.
To keep the valve train as light as possible and still control the valve train, I would recommend:
Option 1:
136 lbs on the seat / 374 lbs over the nose
PSI 1511ML installed @ 1.780" - 66.4 grams
Comp Cams 772-16 or Katech titanium Retainers - 7.2 or 6.0 grams
Comp Cams 623-16 machined locks - 3.2 grams
Option 2:
143 lbs on the seat / 336 lbs over the nose
PAC 1518 installed @ 1.760" - 75 grams
Comp Cams 772-16 Titanium Retainers - 7.2 grams
I think Katech still has their 20% off sale going on, you can get a good deal on the PSI's and associated parts.
For reference here is the PP 8412:
144 lbs on the seat / 374 lbs over the nose
PP 8412 installed @ 1.770" - 94.2 grams
PP 8408 titanium retainer - 10.2 grams
PP 8406 machined super 7 locks - 6.6 grams
Option 1:
Comp Cams 623-16 or Katech titanium Retainers - 7.2 or 6.0 grams
Option 2:
thank you very much!
