where to get fuel pressure gauge
Old Jan 19, 2009 | 10:13 PM
isenegger's Avatar
Default where to get fuel pressure gauge
im looking for a 1.5" or so one that i can put on the end of my fuel rail and leave underhood. i saw a few on summit but i cant tell if they have the adapter for the fuel rail. what do yall have, where did u get and pics would be nice.
Old Jan 20, 2009 | 09:46 PM
isenegger's Avatar
anyone?
Old Jan 20, 2009 | 10:09 PM
Monello's Avatar
Speed Inc has them, they are a sponser.
Old Jan 20, 2009 | 10:22 PM
isenegger's Avatar
so just the gauge and the adapter listed below. is there one from summit or jegs with adapter that is liquid filled?
Old Jan 21, 2009 | 09:43 PM
isenegger's Avatar
ttt..
Old Jan 21, 2009 | 09:51 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
Just curious, what's the benefit of putting a fuel pressure gauge where you can't see it while driving? I guess it's a benefit at idle with the hood popped, but most of the time the issue is when you go wot and high rpm that pressure drops.
Old Jan 21, 2009 | 09:57 PM
isenegger's Avatar
true and im having problems with fuel pressure. it drops when rpms increase. ok so if i was to mount it on the pillar with other gauges what parts would be needed? such as sending unit or what not?
Old Jan 21, 2009 | 11:05 PM
Soul TKR's Avatar
http://www.autometer.com/cat_gaugede...gid=2570&sid=4
Old Jan 22, 2009 | 09:13 AM
UNDER PRESSURE MOD
That way you can take the signal wire as well and log the data if you have data aquisition software like Hptuners. That's my goal because I can then monitor if my fueling issues are related to tune or fuel pressure.
Old Jan 22, 2009 | 09:15 PM
isenegger's Avatar
i just wanna keep tabs on fuel pressure. i would love it in the car. but what piece do i need to adapt the fuel rail to 1/8" NPT
Old Jan 23, 2009 | 09:35 AM
UNDER PRESSURE MOD
Everything you need is in that kit. It contains the sending unit that plugs into the end of our rails, the wiring, and the gauge to go inside the car. Click on the install instructions and you can see what's needed to be done to run it.
Old Jan 23, 2009 | 09:49 AM
405HP_Z06's Avatar
You need one of these:
http://www.casperselectronics.com/st...oducts_id=1337
Old Jan 23, 2009 | 05:49 PM
isenegger's Avatar
cool thanks guys!
