2800 to spend on the WS6, I need recommendations!
Old Jan 21, 2009 | 05:10 PM
MoNoXSizzlE's Avatar
Default 2800 to spend on the WS6, I need recommendations!
Alright we'll in the coming month I'm wanting to budget 2,800 or less into my WS6. Now I have a Torquer 2 waiting for an install in March. So I was wondering if any of you guys got any other advice on what other performance mods should go with my setup. Setup includes; 1 3/4 LTs, Full BMR- Suspension and soon a Torquer 2. Thanks in advance
Old Jan 21, 2009 | 05:15 PM
j0694 ws6's Avatar
id go for heads and an intake manifold
Old Jan 21, 2009 | 05:23 PM
zracer323's Avatar
I would go ahead and get a 9" with 4.11s before the 10 bolt goes, then start saving for heads and a fast 90/90 combo.
Old Jan 21, 2009 | 05:25 PM
Sicko's Avatar
That T2 is alot nicer with a set of heads. 5.3 stage 2.5 heads from Texas Speed will do the trick. If your in there anyways id do it all at once.
Other then that Id possibly look at a 12 bolt or 9inch.
Old Jan 21, 2009 | 05:39 PM
transamsam98's Avatar
moser axle housing package from tick >1100 ebay third member >700 so 1800 then scavange the classifieds for some ported 5.3 or 6.0 heads > 1000 then save your cash and get her tuned. but this is assuming you got an ls6intake manifold.
Old Jan 21, 2009 | 07:31 PM
c0ncEpT's Avatar
I agree 100% with this statement.
Old Jan 21, 2009 | 07:41 PM
xhk651's Avatar
if you are smart, you will get a 9 inch or 12 bolt.. get whichever you can find cheaper..
if you HAVE to have more power.. get a NICE set of heads.. something like trick flows, or AFR's..
id do a killer cam only setup (cam FAST supporting mods) with a 9 inch..
before i would do a H/C setup with a stock rear..
Old Jan 21, 2009 | 07:46 PM
chpmnsws6's Avatar
I'll sell you my built 347 engine for that. H/C and all!
Old Jan 21, 2009 | 08:08 PM
Kikaofazz's Avatar
+1 for 9"
Just do it
Old Jan 21, 2009 | 08:16 PM
beezer1519's Avatar
i have to disagree with everyone since you have some fun money i'd do the heads and intake and then when your rear end goes that's not fun money that's necessary money
Old Jan 21, 2009 | 08:19 PM
Red99TA's Avatar
I wouldn't drop serious cash on a rear unless you actually go to the track with decent tires. I was running 427RWHP on my stock rear and stock clutch without problems although the clutch was probably starting to slip a little bit. With the cam done I would definitely do a good set of heads, LS6 intake (if you don't have one yet), and a clutch. You're going to need it with that much power...450RWHP+. You can easily get heads/clutch for $2800 if you do the install. You can then start saving up for a rear end. If you drag alot more then I would do the rear first for insurance.
Old Jan 23, 2009 | 11:24 AM
I'm seeing a lot of people telling me to fortify the rear-end first and fore-most. I was thinking maybe some nitrous atleast
Old Jan 23, 2009 | 11:32 AM
chpmnsws6's Avatar
For 2800 you can pick up a cheaper used blower kit. Skip nitrous if you can.
Old Jan 23, 2009 | 03:08 PM
xhk651's Avatar
depends on if you go to the track or ever launch your car..
if you dont launch your car (street and roll races) then get power mods... if you launch your car GET A REAR END!!!!!
you are hearing this from people that have been there and done it... i have over 400rwhp and cant launch my car without worrying my rear is going to explode... i have nitrous, and cant use it out of the hole..
why would you spend the entire money on a very base kit??? he is going to end up spending well over 2800 in the long run.. and he wont be making as much power as he could with using the money towards a N/A setup with spray..
why would you "skip" spray? you can go faster for a LOOOOOT cheaper.. granted there are some nice setups out there... but compare that to a sprayed car.... money wise, no comparison..
and yes i understand a killer nitrous setup will run you about a $1500... but a killer turbo or supercharger setup will be multiplied a few times over to get the same power..
skip nitrous if you can...
Old Jan 23, 2009 | 03:47 PM
zracer323's Avatar
You could just not spray it out of the hole. Check out Harris Speed Works. I just got a plate kit with bottle, MicroEdge Controller, bottle warmer and purge kit for less than a grand. Then save the $1800 and use towards a new rear when you can afford it.
Old Jan 23, 2009 | 03:48 PM
xhk651's Avatar
hell if your going that route.... you can get a nice used kit for under 500 easily... with a heater, brackets, purge, gauge, etc..
Old Jan 23, 2009 | 06:55 PM
SunsetOrangeZ's Avatar
Theres a guy selling an STS turbo kit in the classifieds, why not just buy that?
Old Jan 23, 2009 | 08:30 PM
xhk651's Avatar
after he buys that.. i would be surprised if he could stay under that 2800 mark....
when you have a tight budget, you usually should stay away from forced induction..
if it looks like it is going to take 3k... in the long run if you do it right it will end up being 5k with FI..
Old Jan 24, 2009 | 09:38 AM
tonys02slpss's Avatar
I would go with heads or go find you a 9in rear end before your 10 bolt goes out
Old Jan 24, 2009 | 12:21 PM
That would be nice going the FI route but, I'm not sure if I wanna do that just yet. It'd be nice, but expensive eventually I'm sure. I'm thinking either some heads with nitrous though still then I'll go with a rear-end after. I'm not really looking forward to heading to a track either, so mostly roll races
