ls6 heads---243 and the 241's
Old Jan 23, 2009 | 11:33 AM
s10-den's Avatar
Default ls6 heads---243 and the 241's
What is the difference in the 241 and the 243 heads?Both are suppose to be ls6 heads(they both have the triangle tool mark) I have a chance to buy either set and just need to know which ones are better for the money?
Old Jan 23, 2009 | 11:39 AM
NemeSS's Avatar
243 is better, flow more have diff.,bigger intake port, diff. chamber
go with the 243
Old Jan 23, 2009 | 11:40 AM
bjamick's Avatar
243's give prob 20rwhp stock over the 241s . Get the 243.
Old Jan 23, 2009 | 11:41 AM
03Sssnake's Avatar
241 was never used on the LS6, just an updated LS1 head. The 243s were used on the Ls6 mill and will outflow the 241 heads.
Old Jan 23, 2009 | 11:48 AM
jimmyblue's Avatar
Moderator
243s also are found on the LS2 motors, different
valves / springs but same casting. So availability
has improved a lot.
Old Jan 23, 2009 | 12:17 PM
deadmanTA's Avatar
Nothing special about the 241's, they just have smoother ports than the 853 heads. I just gave a set of 241's away because I couldn't sell them and get enough to cover shipping cost out of them.
Old Jan 23, 2009 | 12:24 PM
s10-den's Avatar
Thanks fellas !
"""243s also are found on the LS2 motors, different valves / springs but same casting. So availabilityhas improved a lot"""
-------- Matter of fact, they came off a ls2. Would there be any issues using them on a cammed 'ls1'? Im gathering part for the ls1 swap, figure i could do it cheaper putting parts together.Thanks again
Old Jan 23, 2009 | 12:36 PM
Summerwolf's Avatar
I have LS2 243's on a cammed LS1...worked perfect.
I had them rebuilt and lots of portwork done before installation but same difference more power.
Old Jan 23, 2009 | 01:42 PM
bjamick's Avatar
799 castings are also the same as 243 just so ya know
Old Jan 23, 2009 | 05:17 PM
s10-den's Avatar
Thanks, I didnt know that.
Old Jan 23, 2009 | 05:42 PM
deadhorse66's Avatar
Yep. I have a set on my pickup, and they gave it a MAJOR shot in the arm. That's the chamber in my sigline after I polished it.
Old Jan 24, 2009 | 08:48 PM
wht01ws6ta's Avatar
GM started putting 243s on more engines lately, I've seen them on a stock 4.8L truck engine. Not sure if that is the exact same valves/springs as the 243s on the LS2 but I wouldn't doubt it.
Like stated above, the 241s never went on the LS6 and 243s always flow better.
Old Jan 25, 2009 | 04:57 PM
02BLKWS6MD's Avatar
yeah they're on 4.8,5.3 and I think 6.0 trucks. They even use them on the 5.3 Impala SS and Monte Carlo SS.
Old Jan 25, 2009 | 05:37 PM
wht01ws6ta's Avatar
I knew it was quite a few of them so, yeah, they are definitely out there. 6.0 trucks should be 317 heads unless its an older model.
Old Jan 25, 2009 | 11:48 PM
The 6.0 gets the rectangle port head these days.
Old Jan 26, 2009 | 06:36 AM
s10-den's Avatar
Guess I should ask are all the 243's the same cc's?
Old Jan 26, 2009 | 11:22 AM
02BLKWS6MD's Avatar
Yeah I was thinking they were the motor with the different heads. Just wasnt to sure on that. I see that the 317 heads are being used on alot of setups now, is there any reasoning behind this? I've seen a few FI cars with them, do they work better with FI since they have more CCs?
